Old 02-25-2013, 11:49 AM   #15
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
We are same age....and I am in good shape, but wouldn't even consider expending energy with a manual jack....go electric and thank Edison and Tesla.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 02-25-2013, 12:04 PM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by buffaloman View Post
I started to install the Barker jack yesterday. The mechanical part seemed easy except for the five trips between the trailer and the tool shop for the correct wrench size, etc. I need the exercise anyway. The rain didn't help my depression much either. LOL
Mechanically it was easy but I need to figure out if I can wire the positive lead into the trailer light plug or have to run a separate wire under the trailer to the battery. Anybody know?
I would run a dedicated wire, 12ga, with a in-line fuse and or circuit breaker, wire it so the jack can be used even when the battery switch is in the store mode.
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-25-2013, 12:38 PM   #17
1974 Argosy 20
Kooskia , Idaho
On that year Argosy, just use the wire which is the +12 volt charge line from the car umbilical cord. It is also the same wire that the break away switch is connected to. It is hot all the time.
Old 03-01-2013, 10:20 AM   #18
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
idroba, I didn't read your post until after I contacted Barker. Their service department suggested I contact Airstream and there I received the suggestion that I wire into the break away switch but to be sure to have the slow blow 30 fuse in place. The Barker service rep, Greg, also said that if I was in a pinch that a regular 40 amp fuse would work and to then call the factory to get some free slow blow fuses as spares.
This experience only underscores the "BUY AMERICAN" because this company gives great customer service. Now I'm off to wire up the jack in this lovely rain storm. In Darrington, it rains about 60-80 inches a year. No wonder I have a trailer to travel LOL Now only if diesel were $1.50 per gallon.
buffaloman is offline   Reply With Quote
Old 07-27-2013, 03:00 PM   #19
1975 31' Sovereign
Olalla , Washington
well after reading these and other comments/reviews, I purchased a Barker VIP 3500 jack. I spoke with the sales person regarding the different model features of Barker jacks. Ironically he said the VIP and next jack up were actually the same expect for the cost.
It should arrive this weekend so I'll see how difficult installation is.
BTW two important reasons for buying a Barker is 1) many many good comments about customer service 2) MADE IN USA.
I've also decided to buy the Barker VIP 3500 jack. I'm pretty sure that is the one with a 24" lift and a 2 1/4" diameter post.
How's it working out for you?
Was the 2 1/4" diameter post the correct size?
swirkus is offline   Reply With Quote
Old 07-27-2013, 08:30 PM   #20
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Got it. Per recommends here. It works great! I do have a little "squeak" from jack when extending/lifting AS. I wonder if it needs oiling "out of box"?
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-28-2013, 05:01 AM   #21
Thumbs up
WD40 on the "shaft".....spray,work & wipe down.
RLC
John Prine
Old 07-28-2013, 08:11 AM   #22
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I take the fuse out of the jack when it is storage and put it in the truck ash tray. Helps to slow down vandalism and or theft.
