Old 05-04-2014, 01:33 PM   #1
Tongue jack problem
We have a year old electric jack on our '71 Safari and it has worked great. Now, all of a sudden, it won't work. All fuses are good, including on the Univolt. We also have new batteries. Any ideas what the problem might be?
Dbraw is offline   Reply With Quote
Old 05-04-2014, 01:47 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Did your check of fuses include the in-line fuse between the jack and the battery? It may not be easily visible unless you look under the tongue.
TB & Greg and Abbey Schnauzer
#3954
TBRich is online now   Reply With Quote
Old 05-04-2014, 02:10 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What is the manufacturer of the jack? Did you check if there is power at the jack? Did you check if there are any internal fuses in the jack?
Old 05-04-2014, 02:35 PM   #4
The jack is an Ultra 3002. There is power at the jack 12.56 volts. The fuse in the tounge is not blown.
HELP
Old 05-04-2014, 02:41 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
I am not familiar with the Ultra. I assume you will be calling the manufacturer for troubleshooting. Any trouble shooting info on the Ultra website? Any chance of a bad ground? In the mean time is there a hand crank?
Old 05-04-2014, 03:38 PM   #6
I emailed the manufacturer and expect a reply tomorrow. There is a hand crank and I have been using it. Yuck!
Old 05-04-2014, 05:34 PM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The ground to the jack is through the bolts that attach the jack at the frame. Try loosening then retightening the bolts. Only loosen one bolt at a time.
Alan
Tongue Jack Problem El Gitano Jacks, Stabilizers, Lifting and Leveling 5 09-29-2013 05:35 PM
Tongue jack problem Shads Shack Jacks, Stabilizers, Lifting and Leveling 1 05-02-2013 03:02 PM
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
