Old 07-20-2015, 12:35 PM   #1
2015 30' International
Duvall , Washington
Toilet leak 2015 30' International
So all of a sudden the black water valve has a subtle leak. Sometimes every few days. Help, pls.
Scottiesafar is offline   Reply With Quote
Old 07-20-2015, 12:53 PM   #2
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
So when you open the dump valve a whole lot of sewer water comes out or just a slight trickle. Have you left the cap off and with a container underneath does it start to fill? After I dump there is always some fluid left in the drain pipe that eventually settles against the drain cap.
Does the black tank valve seem stick or does it open and close smoothly?
Try this. Make sure gray and black valves closed. Put a 5 gallon bucket under the drain valve. Open the cap. Spray water into the opening until the water comes back in a good flow. It may be close to filling the bucket by now since you have to angle the bucket to fit under the drain. Once its flowing clean then leave the cap off to let it dry out then replace the cap. Come back a few days later and remove the cap to see if any black water comes out.
It could be the seals are dried out. You can add some holding tank chemicals to lubricate the valve seals.
http://www.amazon.com/Camco-40246-Dr.../dp/B000EDSSG6
Kelvin
NorCal : 2015 Jackson Rancheria Fally Rally October 9-11, 2015 Coastalview Forum Rallies & Meet Ups 48 05-30-2017 01:49 PM
2015 International 30 vs 2015 Classic ZBoater 2011 - 2015 International 41 05-28-2015 08:47 AM
Toilet leak 2015 flying cloud Jukeboxfun Sinks, Showers & Toilets 17 05-01-2015 08:29 PM
2015 GMC Yukon Denali 4WD & 2015 Flying Cloud 30 ? DHart Towing, Tow Vehicles & Hitches 22 04-09-2015 07:01 AM
2015 MOUNTAIN AIR Rally April 17-20 2015 shermantic Forum Rallies & Meet Ups 2 01-13-2015 07:43 AM
