Old 07-06-2015, 01:16 PM   #1
jdlimages's Avatar
1961 22' Flying Cloud
Oklahoma City , Oklahoma
To Paint or not to Paint my AC Cover?
Just wondered if anyone has ever painted their air conditioner cover silver? Mine is disolored in spots and thought it might look cool silver. Or it might look trashy. If so what kind of paint did you use? I bought some silver spray paint and I also have a can of "Zinc It" which puts a coat of silver zinc on it. This shouldn't cause any overheating problems with the A/C should it? Will the paint flake off? What are the general thoughts on this from the community? Thanks.
jdlimages is offline   Reply With Quote
Old 07-06-2015, 01:43 PM   #2
1998 30' Excella 1000
Livingston , Texas
Check out this thread:
http://www.airforums.com/forums/f427...it-116898.html
Siegmann is offline   Reply With Quote
Old 07-06-2015, 02:05 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I know a guy who had his AC covers painted silver to match his trailer. I believe that he had an auto body shop use automotive paints to do this. It looks great.
Bob Martel
WBCCI# 5766
Old 07-06-2015, 02:33 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
You can use spray paint, but it probably won't last very long, especially if exposed to sun. I would have an auto body shop paint it. Make sure they use an adhesion promoter while prepping.
Cochese is offline   Reply With Quote
Old 07-07-2015, 10:26 AM   #5
1976 27' Overlander
Delta , British Columbia
I painted mine with a spray primer, and then an Aluminum coloured spray paint, lastly top coated it with a clear lacquer spray. Only did it this year, it looked horrible before and looks great now. Sorry I can't comment on the durability, but for $20 in products and about 2 hrs it was a huge improvement.
This was on a 76 Overlander
photo on this link
http://www.airforums.com/forums/f170...er-136797.html
Seabloom is offline   Reply With Quote
Old 07-07-2015, 12:50 PM   #6
1996 25' Excella
Tillsonburg , Ontario
Use Krylon spray paint ...comes in many colours including silver and aluminum. Home Depot and hardware stores, etc. It is made for outdoor furniture, and stands up well to sun. I have also used it to cover plastic laminate cabinet doors. Watch out for the re-coat times. If you do not re-coat within 24 hours it will bubble. If you miss the timing then you need to wait for about 7 days I think.
Very easy to apply
JCW
JCWDCW is offline   Reply With Quote
Old 07-07-2015, 01:18 PM   #7
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I painted my AC cover with silver Rustoleum in 2012 and it still looks good today!
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 07-07-2015, 08:08 PM   #8
We also sanded the original plastic shroud, painted with Krylon silver, then a Krylon clear coat. That lasted until we replaced the AC unit 7 years later. I did the same thing with the new shroud.
Old 07-07-2015, 08:28 PM   #9
1979 23' Safari
Wayland , New York
If you use the krylon fusion be sure to use it outdoors, I just sprayed my front end cap in a large garage, to say that it has overspray would be an understatement, seemed like more paint was going into the air than on the surface. Had white 'dust' on everything. Took 6 cans to get good coverage.
Been using primer in there without similar problems, about 15 cans of it.
I would consider an auto paint shop, they have a professional primer especially for plastic(bumpers etc) that works really well. Then they can color spray and clear coat.
Old 07-07-2015, 08:37 PM   #10
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Like the idea. I have been thinking about painting my AC and vent covers gray.
MICHAEL
Old 07-07-2015, 09:48 PM   #11
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Hit my old Dometic on the 3411 with some primer and then used Krylon Fusion. Still fine when sold two years later after this punishing environment.
Old 07-08-2015, 10:11 AM   #12
jdlimages's Avatar
Great! Thanks for all the good info. Now I'm not so scared to try it since it has worked for so many. Gotta love the Forum.
To cover or not to cover? steveirving Winterizing, Storage, Carports & Covers 9 07-28-2014 07:31 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
Cover or not to Cover? Sixty3TW4US Winterizing, Storage, Carports & Covers 7 09-16-2008 12:08 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 07:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
