Old 08-01-2012, 02:32 PM   #1
1977 28' Argosy 28
Southaven , Mississippi
To oil or not to Oil
I bought a 1977 Argosy 28 with 42K miles with a 454 engine. It sat behind a barn for about 10 years. I was able to start it and move it under it own power.I want to drain and replace all fluids. I was told by someone that I need to use Oil with Zink in it. He said the Zink coats the metal moving parts.
This is my first Class A and dealing with one this old, I have to consider this might be true. I'm also thinking that Lucas oil treatment would do the same thing. Does anyone have any knowledge they can share on this.
Thanks in advance
Woody
woodyarn is offline   Reply With Quote
Old 08-01-2012, 02:40 PM   #2
SteveH's Avatar
Common Sense , Texas
I would check with Chevrolet to see what oil they spec'ed in '77, and whatever you do, don't put synthetic oil in the engine or you'll never get it to stop leaking, if it doesn't already.
Old 08-02-2012, 04:00 AM   #3
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
FWIW. I was told by a couple of guys who re-build engines they use Shell Rotella to break them in because it has zinc. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 08-02-2012, 07:34 PM   #4
richinny's Avatar
2011 34' Classic
that's good to know sal. a quick search indicates that they've lowered the amount but it still has a fair amount in it.
Ricky
Old 08-02-2012, 07:52 PM   #5
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
You can buy zinc additive to add to any modern oil. It is needed in older engines to prevent camshaft wear. I put Valvoline VR-1 in my '64 Alfa, because it has zinc content and could be a good choice for the 454.
robert claus is offline   Reply With Quote
Old 08-02-2012, 08:00 PM   #6
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
This is one of those "old wives tales" that keeps circulating and repeating....
I do this for a living and we use lots of synthetic oil in lots of car engines both old and new. Something in the order of thousands of gallons of synthetic oil annually....
We get no more oil leakage on old engines using synthetic than we do in old engines using non synthetic. No more at all! Not even a little!!!!!!
I believe this "advice" comes from the very first synthetic oils when the base stock was a very different chemical than that produced today (today being the past 15 or 20 years). Castrol had a very good Q&A on this subject on their website at one time explaining the details.
On the subject of zinc, I understand that oil companies have removed the element from their additive packages as its presence hurts catalytic converters ???
There are oils formulated for pre catalyst engines that contain more zinc as it is beneficial to those engines. I personally do not believe your vintage engine will really suffer without the zinc though. Oils are so much "better" than what was available 25 years ago....
Bruce
Bruce B is offline   Reply With Quote
Old 08-02-2012, 08:05 PM   #7
SteveH's Avatar
Bruce
Whatever you say, Bruce, but I will tell you I have put sythetic oil in three different vehicles in the last few years that were broke-in and ran several years on conventional oil, and all three started leaking oil from the rear main seal. Please have Castrol give me a call, or maybe their old wife???
Old 08-02-2012, 08:09 PM   #8
Bruce B's Avatar
I have done it on many hundreds without anything leaking....
I cant tell you why yours are!
Maybe it is time for a different brand??? Just kidding....
Engines leak oil, some more than others but synthetic is not the root cause.
Bruce
Old 08-02-2012, 08:13 PM   #9
Bruce B's Avatar
If you do not like Castrol, try Mobile One's site's FAQ's....One of the best motor oils in the world today!
Bruce
Myths About Synthetic Motor Oils
Old 08-02-2012, 08:15 PM   #10
SteveH's Avatar
Not that it really matters, but just so you know the variety of engines, one was an '04 Jeep 4 Liter 6cyl, one a 383 Chevy in a streetrod that I built, and the last one, an '08 Durmax Diesel.
All started leaking from the rear main seal after changing to synthetic oil, the two gas engines was Mobil 1, and the Duramax, Rotella.
I also use sythetic in newer engines after the first 1000 or so miles, and no leaks, but the three above had some years and miles on them with conventional oil.
Old 08-02-2012, 08:20 PM   #11
1981 31' Excella II
New Market , Alabama
They replaced zinc with other stuff that does the same thing. Synthetics are good but I would probably go with a diesel synthetic oil like the Rotella-T or what ever they call it now. As long as the oil pressure it good you should be ok.
Perry
Old 08-02-2012, 08:22 PM   #12
Check out this web-site, " Bradpenn.com" this was the former Kendall/Amalie refinery located in Bradford, Pa. and they manufacture a line of oil with Zinc that will work in your 454 they may be able to help. Good luck.
dano is offline   Reply With Quote
Old 08-03-2012, 04:13 AM   #13
1981 31' Excella II
Why is zinc such a big deal? GO to bobistheoilguy forum and those guys can tell you everything you need to know about oil.
Perry
Old 08-03-2012, 06:00 AM   #14
Skater's Avatar
1995 30' Excella
Bowie , Maryland
While we're trading anecdotes, I put synthetic in three vehicles too (my '91 B190 with >100K miles, my '04 Impala with 30K miles, and my '99 Cougar with 60K miles) several years ago, and not one started leaking oil. So it sounds like your experience and my experience cancel each other out.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
