Old 06-09-2014, 04:48 AM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by lcurrie View Post
Got my air, just had to take matters into my own hands. Had my spare, it was just flat. For those of you that camp with me when my parents are there, if you tell my daddy that I had a flat spare, I will never speak to you again.
$50 for each of us, and our lips are sealed.
Old 06-09-2014, 05:37 AM   #16
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Check Northern Tool's website for a double ram bottle jack. Low enough to fit under the Airstream and still tall enough to do the job.
Old 06-09-2014, 07:38 AM   #17
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
Originally Posted by richw46 View Post
Just so the different jack types are understood, here's a picture.
Thanks for the pictures, my preference is the scissor jack all the way.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 06-09-2014, 08:30 AM   #18
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Tire Jack On Board?
Scissor jacks are notorious for failing as they easily lie down if not used on a hard level surface.
This is really of no dire consequence except for those who think they can work under a vehicle supported by a jack.
Just sayin.....i never work under anything on a jack and I will ream anyone I see doing so. The bad part is, i have had to ream a lot of people for this.
Old 06-09-2014, 09:15 AM   #19
Goal15's Avatar
Dallas , Texas
I stand corrected
Tundra comes with the screw bottle jack.... which I have been able to use very successfully on the Airstream to change tires on a couple of occasions.
I am, however, sorry to hear that Good Sam's tech wasn't properly equipped... We have their roadside assistance based on the many positive reviews found here, but this seems like a pretty basic thing, a jack and air.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 06-09-2014, 09:31 AM   #20
richw46's Avatar
Lexington , Kentucky
I like the scissor jacks because they have such a vertical range. You can get them under just about any vehicle with a flat, they need only a few inches (4-6") of clearance. Then they extend up pretty high, about 20" and are lightweight. The only downside I can see is that 2 ton is about the maximum for a tire changing scissor jack. I have found leveling jacks that go higher but I'm not sure how well they would work for tire changing because they are flat at the top, no indentation for an axle, cross member or jack point.
I would never get under a vehicle on just a jack. I always use jack stands and then I put a concrete block under a cross member before I get under it. I was stationed at Fort Benning, GA when a Sargent, just back from his 3rd tour of Vietnam, got crushed when his car slipped off the jack; lesson learned.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 06-09-2014, 09:39 AM   #21
richw46's Avatar
Same in my 4Runner, they are excellent jacks and I think they are for up to 3 ton. They are expensive to replace. I think they are around $100 but that's Toyota's price. I can't find one anywhere else.
The bottle and screw bottle are similar but one is hydraulic and the other mechanical. Never have to worry about losing fluid in a screw bottle, an excellent advantage They also are short but extend up pretty high. I've used it on my boat trailer a couple of times, never on the AS though.
-Rich
Rich & Yvonne
2004 4Runner SE
Old 06-09-2014, 11:28 PM   #22
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Now I gotta chime in; Unless that CMU, or concrete masonry unit, or cinder block, or what ever name it is called in your woods; is filled with concrete or grout, it is almost as fragile as setting on a cardboard box. Strike the side strongly with a hammer and it will crack, break, shatter. The strength in masonry walls comes from filling the inside cells with grout; which is concrete with small pea gravel size aggregate. This makes a solid wall of concrete. Deceptive strength if you're standing straight on the top, drop a weight on the side and it will break, easily. Fill that CMU before you get under
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 06-10-2014, 12:12 AM   #23
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Putting the tires and wheels under the vehicle is a common safety backup for a vehicle up on jack stands.
It could save your bacon.
Old 06-10-2014, 06:10 AM   #24
richw46's Avatar
Well, like I said, the car is on jack stands and the concrete block is on its back with the sides vertical, not on its side. It's also right under a cross member so there's no room for the car to drop any further. I have used a block to support the car weight while I shift the jack stands. I know that these blocks can break but you have to strike them, drop them or have something fall on them. They are a secondary backup for me. But thank you for your concern.
-Rich
Rich & Yvonne
2004 4Runner SE
Jack placement for tire change ferrygj99 Tires 4 05-10-2013 08:15 PM
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
