Old 07-23-2013, 09:32 PM   #1
lrw
2007 30' Classic S/O
Ann Arbor , Michigan
Tire change tricks
We found ourselves with our first flat tire on our 2007 Classic trailer when we got home Sunday and my husband cannot get the bolts to loosen. He backed the tire up on a couple of boards. Is there a special trick to this?
lrw is offline   Reply With Quote
Old 07-23-2013, 09:47 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
SeeMore is offline   Reply With Quote
Old 07-24-2013, 01:10 AM   #3
kevinb's Avatar
1968 24' Tradewind
1959 17' Pacer
holly springs , Georgia
Buy an inexpensive 1/2" impact wrench, if you don't have an air compressor electric ones are also available.
kevinb is offline   Reply With Quote
Old 07-24-2013, 03:34 AM   #4
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
loosen them before you raise the tire off the ground
rbs is offline   Reply With Quote
Old 07-24-2013, 04:17 AM   #5
1971 29' Ambassador
Leonardtown , Maryland
Use a 6 point socket. Do not use a 12 point.
Do not over torque the lugs when you put them back on, your owners manual has the torque values for your rims. I also use Anti-Seize on the lug nuts.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 07-24-2013, 04:33 AM   #6
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I do not believe Airstream recommends anti-sieze on the nuts. The lubricant effects the resultant axial load on the stud and may over stress them.
Old 07-24-2013, 05:31 AM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
Keep the threads clean and dry.
Swap the chrome capped lug nuts. with these. (the cheep chrome cap loosens over time)
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-24-2013, 07:13 AM   #8
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
A 4 foot piece of waterpipe in the airstream bumper makes all the difference in the world when changing a tire.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 07-24-2013, 07:21 AM   #9
withidl's Avatar
2002 31' Classic
Houston , Texas
Absolutely Do NOT Use Anti-Seize!!!!!
As per the others, DO NOT USE ANTI-SEIZE!!
withidl is offline   Reply With Quote
Old 07-24-2013, 04:46 PM   #10
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
I carry a 30" breaker bar in the trailer to loosen the nuts and a torque wrench to tighten them. As mentioned above, DO NOT USE ANTI SIEZE. The torque values are given for clean, dry threads. I have also used a 4-way wrench with the pipe used on the hitch slipped over the wedge end to get plenty of leverage.
If someone has previously used an impact wrench without proper torque limiting, you may have stretched studs. The nuts are hard to remove and both the nuts and the studs may be damaged. I carry an 85 fp torque stick and then bring the torque up to 100 fp with the torque wrench. No one will ever put a torque wrench on my lugs without a limiting device.
John W. Irwin
WBCCI #9632
Old 07-24-2013, 05:37 PM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
A small can of spray penetrating oil might help with the caveat of cleaning all traces of the oil off the wheel studs after getting the wheel off the trailer.
Old 07-24-2013, 06:49 PM   #12
Pahaska's Avatar
Hays County , Texas
Not a good idea. Oil is oil. The threads will be clean and dry, having been protected inside the nuts and should not be oily to start with. The most I do is a quick wipe of the studs with a dry rag.
John W. Irwin
WBCCI #9632
Old 07-24-2013, 10:45 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ignore everything that follows. you will not have success using my method. (End disclaimer)
Once lug nuts and wheel are off, check for rust. If rust at base of std, clean with stranded steel wool. Carefully make a strand of several polled from roll. Use like dental floss held by both hands to "brush" the stud threads. Then clean and dry. If severe rust, consider replacing all studs and lug nuts.
When properly made wheel mates with drum or disc there should be no water between them. So rust won't form.
If, however, you are a fan of pressure washers, you may be causing problems.
Now, some cheaper lug nuts do not have a cap or the cap does not seal well. Water can and will find its way in and will rust stud and nut!
I have used "nev-r-seize" on boat wheel lugs and nuts for 50 years. I apply sparingly...drive then check torque as described above by competent AS owners.
My lug nuts are cheap open headed and I run the hot wheels underwater when unloading boat... So the bearings get clobbered if bearing buddies or seals fail... But no problem with loosening lug nuts, no rust on threads.
With aluminum wheels I do same and a very light near on the lugnut and wheel mating surface... If any squishes out, you put too much...remove and clean up.
When installing studs I do same, light coat of NS then press in.
By far, using too much torque will kill the threads on stud and nut and I think is primary cause of early life failure (stuck lugnut).
When removing, I don't get the groaning of metal shearing when I have used NS on lugnut, stud and wheel. I have only replaced "factory" and "tire dealer" installed lugnut and stud.
Of course you must ignore my method. I read this after using my method and my head exploded around page 2.. http://mmptdpublic.jsc.nasa.gov/prc/7085a.doc
And.
http://ntrs.nasa.gov/archive/nasa/ca...2012004005.pdf
Then again, that is NASA and I am NOT a rokit zientus.
C'mon guys... Travel well!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-25-2013, 10:07 PM   #14
lrw
Lugnuts off now to find tires.
Thanks everyone. All your comments helped and tire is off. Removed the boards and had it back on the ground. Used a breaker bar.
Will get it checked out tomorrow. Probably price four new tires; trailer is six years old. We bought it last year and expect they are the original.
