Old 09-18-2019, 09:14 AM   #1
2014 22' FB Sport
Atlanta , Georgia
Those damn European hinges
I'm not a Europhobe, but they can keep their damn hinges. Meanwhile I keep having them come apart (not in a position to post pictures). Remember, there's a piece on the cabinet box and a piece on the door. the piece on the door shoehorns into the piece on the box, but my getting them back together is a matter of luck, not skill. I've looked on line. It seems to be one of those things that's so easy that nobody has posted anything about it . Can some one give me a clue about what the approach is?
Belbein is offline   Reply With Quote
Old 09-18-2019, 09:22 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The part closest to the hinge needs to engage the fixed mount on the doorframe first, then the far end can be clicked in pretty easily. I've built 3 IKEA kitchens over time, this is very familiar hardware.
It might be helpful to dismount a single hinge from the door so you can easily mount and dismount it from the fixed part on the doorframe without having to fiddle with the door itself, until you get a feel for it and then it'll be easier to know how to hold the door to align the mechanism.
One thing I notice about the brand Airstream uses is that the little release lever on the far end from the hinged part is too easy to accidentally snag and pull, which is what leads to the repeated disconnections. And of course I only knock one loose when I'm tired and inattentive and it's 10x more frustrating to put back together because of that.
— David
Old 09-18-2019, 09:33 AM   #3
2017 28' International
Baileys Harbor , Wisconsin
My problem has been that some of them come apart because the screws come loose. They are little and very hard to find on the floor. Basically have to replace an entire hinge just because of one screw because hardware stores don't carry them. Dumb.
I will AS would stop using them, or at least someone could explain WHY they use them.
Daquenzer is offline   Reply With Quote
Old 09-18-2019, 09:39 AM   #4
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
Problem solved. The end can be clipped after the zip tie is tight. When door is closed nothing is visible.
az-streamer is offline   Reply With Quote
Old 09-18-2019, 09:40 AM   #5
Images: 20
Sorry about sideways pic
Old 09-18-2019, 09:46 AM   #6
DKB_SATX's Avatar
1976 Argosy 28
It's not you, it's your iThing not playing well with creaky old Apache servers.
— David
Old 09-18-2019, 10:21 AM   #7
Attachment 352431
Very good idea. Thanks!!
Old 09-18-2019, 09:22 PM   #8
2018 28' Flying Cloud
Fairfield , California
Go to woodworkerexpress.com and check out Tiomos Clip Protector, part# 1ZV639070301924596, their item # 11289919. These clips snap over the hinge release tab to eliminate it accidently releasing. 42 cents each. I just installed last week on every hinge on my AS. It only took a couple of minutes to do them all.
Thanks to a recent thread on this, which is where I picked up this information and solution.
StuartsDad is offline   Reply With Quote
Old 09-19-2019, 04:59 AM   #9
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I bought the little grey plastic clip things. They seem to mostly work, but I still have one or two that come apart, as noted above, because a screw comes loose. Pain in the keister.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 09-19-2019, 08:32 AM   #10
DKB_SATX's Avatar
1976 Argosy 28
Thanks for that, I think I'll order a bucketful. However, I think you posted the tracking # for your order rather than the part #, since 1ZV is a UPS tracking number prefix. It looks like the part number shown at WoodworkerExpress is F072135807540 and their SKU is 11289919
— David
Old 09-19-2019, 09:28 AM   #11
2019 25' International
Washington , Washington, D.C.
az-streamer - very simple solution, very nice, thank for sharing! (And a whole lot less cost-wise than the plastic Tiomos clips).
PatLee is offline   Reply With Quote
Old 09-19-2019, 10:36 AM   #12
2018 27' International
Sharpsburg , Georgia
Attachment 352431
I zip tie mine too and it was a game changer. ����
Odysseyon is offline   Reply With Quote
Old 09-19-2019, 11:00 AM   #13
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Plastic clip thingies look like a winner. BUT... on a slightly different tack, the drawer slide clips are even more inscrutable to reattach. Any primer advice for the clumsy Euro-challenged? Thnx for the thread hijack/diversion.
Question: better to be a successful pessimist or a failed optimist?
Al & Robin
2018 Airstream 23FB Flying Cloud
2015 F150 XLT 3.5L EcoBoost, 4WD
almcate is offline   Reply With Quote
Old 09-19-2019, 11:00 AM   #14
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Keremeos , British Columbia
Images: 30
Airstream provided us with a baggie of these clips (for free) when we were at the factory in May. Maybe try calling the Airstream store.
Lisa
Lisa and Paul
https://atomicpod.wordpress.com
2017 30' FC | 2002 Chinook Destiny | 2008 23' Int. CCD (written off: hail!)
Full-time since July 31, 2017
bolerama is offline   Reply With Quote
Old 09-19-2019, 11:18 AM   #15
2018 27' Flying Cloud
Issaquah , Washington
Hinges
My under sink doors came off during my last trip. I found these tiny screws on the floor. Where do they go? I looked all over the internet and no luck. This so frustrating.....Thanks for any help!!
ElBrillante is offline   Reply With Quote
Old 09-19-2019, 11:38 AM   #16
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
I did the same (tie wrap), a cheap and quick fix that works!
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap,
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 09-19-2019, 01:42 PM   #17
CruizinDux's Avatar
Tracktown USA , Oregon
Mike
Screws coming loose. Imo,biggger the prob. I usec tape at first then went with the zip ties. They don't release anymore but the srews docome lose. thinking of some !octite or =.
I was going to buy a doz or of the c!ips above, buy the shiping was more than the clips.
B
P.s. The reinstall trick is to focus on the very small round tabs on the base side, the cabinet slips over them and pivots to lock/click at the end
CruizinDux is offline   Reply With Quote
Old 09-19-2019, 02:34 PM   #18
2017 20' Flying Cloud
austin , Texas
During a Q&A with Justin Humphreys (AS VP) and Rick March (General Manager Customer Relations Group) at the 2017 International Rally, I explained the problem with the European hinges. Rick said there are plastic clips that are sent with all models to the dealers and it's up to the dealers to put them on the hinges. Rick then passed around a sign up sheet for names/addresses for free plastic clips (which I did receive). I wonder if you called AS Service Dept if they'd send you some (?).
During my last annual inspection at the dealer, I did bring up the plastic clips and they had no idea of what I was talking about.
ejami5 is offline   Reply With Quote
Old 09-19-2019, 02:50 PM   #19
DKB SATX. Thanks for catching my part# error. Mfg part# is F072135807540.
Old 09-19-2019, 03:11 PM   #20
ProTech's Avatar
2015 23' FB International
Portland , Oregon
Attachment 352431
That's Brilliant.
ProTech is offline   Reply With Quote
European Cabinet Hinges MaiziesGang General Repair Forum 26 03-01-2019 06:55 AM
Damn those distractions. Isuzusweet Classic Motorhomes 21 07-26-2016 06:20 AM
why does Airstream put so damn many.... carl2591 Off Topic Forum 24 11-23-2015 08:43 AM
DAMN GFI Breaker dan50w Lights - Interior & Exterior 13 12-24-2009 12:59 PM
damn door chas trotter Doors & Locks 4 04-18-2005 12:14 AM
