Old 02-07-2013, 03:19 PM   #1
1978 25' Tradewind
silverhill , Alabama
This Weekend Proud Owner of a 1977 TradeWind
Need help in finding the correct door latch for my 1977 AS, past owner no longer has the broken latch to compare, Does most models have or use the same latch? and where can I purchase a the correct latch?
woody7725 is offline   Reply With Quote
Old 02-07-2013, 03:40 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I'm not 100% sure about your specific trailer, but most of the mid-70s Airstreams and Argosy trailers used a lock that isn't available new anymore, called a KT entry lock. There's one on eBay at the moment claimed to be new old stock for the low-low price of $425 (plus shipping.) I've seen some doors retrofitted with a different door latch that requires a patch panel on the hinge side of where the KT was because it doesn't fill the entire space, but I don't know if those kits are available or how much they cost.
edit: Here's a post with a picture of the retrofit kit.
David
DKB_SATX is online now   Reply With Quote
Old 02-07-2013, 03:56 PM   #3
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
The KT lock shown on ebay is the same lock that is on my 1976 Sovereign. Maybe someone will confirm that it was on the 1977 as well. You can see it by searching ebay for KT entry lock. It should come right up. It sure looks new and I would say is a good price if you need one.
I had the lock on my 1976 replaced a few years ago with a rebuild lock after someone tried to break in. The rebuilt one was about $350.
Check with Inland RV and see if they have anything.
Don
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
