Old 11-06-2016, 04:02 PM   #21
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The pressure switch is mounted on the pump. It will have 2 wires connected; one is the +12 volt; the other goes to the pump motor.
You should see 12 volts on one of the wires if the on/off switch is on.
Old 11-07-2016, 02:20 PM   #22
2005 25' Classic
SomeWhereIn , South Carolina
Thanks for all the replies. It's amazing what you can learn when you tear something apart!
Found a diagram of the pump/switch combo on the internet. Took off the switch, appears to operate freely. Started taking apart the pump portion and noted the bearings appeared corroded and seized. Took off the motor end cap, and it appears that water had crept its way in there as well.
Time for a new motor/pump. $155 on amazon. Not the 20 cent fix I was hoping for. But, livin' and learnin'. God is good!
smokinjoe is offline   Reply With Quote
Old 11-07-2016, 04:24 PM   #23
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Be one of the easier, cheaper fixes you will have over the life of the trailer, I expect. I have put 3 pumps into my 2 trailers over the last 8 years. It could be that whoever winterized it missed the pump. One of my repairs was a pump was damaged by a PO who lived in Vermont and did not winterize his first year. I knew it had frozen and been partially repaired before I bought the trailer so I have no complaint.
Old 11-07-2016, 05:09 PM   #24
1999 30' Excella 1000
small town , Maryland
Thanks for giving us the solution to the problem smokinjoe. It gives everyone that gave friendly advice closure. So often we never find out what the cause was to the problem. So start planning your next adventure. I here that Disney's Fort wilderness is awesome, for kids of all ages. Might make a great Christmas gift for everyone.
streaminwild is offline   Reply With Quote
Old 11-07-2016, 06:22 PM   #25
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You can find a pump that is less than $155.
Old 11-20-2016, 09:06 AM   #26
2005 25' Classic
Replaced the pump and it appears to work just fine now. Cycles on and off quite a few times if the water is running. I'm guessing this is common.
Old 11-20-2016, 09:30 AM   #27
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
It is common for the pump to cycle or just straight run if you have faucet/faucets open. If it cycles with faucets closed there is probably a leak somewhere in the system......
1973Argosy is offline   Reply With Quote
Old 11-20-2016, 11:01 AM   #28
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I added an accumulator tank (see http://www.campingworld.com/shopping...eel-tank/14747 ) and the cycling is reduced - as well, there is no surging of the water flow, especially when showering.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 11-22-2016, 03:31 PM   #29
2005 25' Classic
I may look into that in the future. Still working a few of the bugs out for now.
Wet Cell Mucho Thirsty! PharmGeek Batteries, Univolts, Converters & Inverters 46 10-16-2014 01:05 PM
Who's Thirsty???? Bluemoon64 Off Topic Forum 6 11-27-2013 06:42 AM
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Do I need More Torque or More Horsepower? mdeneen Tow Vehicles 52 11-02-2004 06:06 PM
