Old 09-15-2012, 02:49 PM   #1
1978 31' Sovereign
austin , Texas
Thermostat question
I have completely gutted my airstream and am in the process of rebuilding. My question to you experienced renovators is does the thermostat just run the suburban propane heater?
firegreg1 is offline   Reply With Quote
Old 09-15-2012, 02:57 PM   #2
1978 31' Sovereign
austin , Texas
Just to clarify I have a 1978 31 foot sovereign.
Old 09-15-2012, 03:00 PM   #3
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
The original thermostats only run the furnace. You can get newer models that will also run the AC and wire it that way, but most Airstreams run the built-in thermo right on the AC, and a separate one for the furnace...
Friday is offline   Reply With Quote
Old 09-15-2012, 06:35 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The 78 Excella 31' that I used to own had two thermostats. One thermostat was mounted beside the refrigerator that operated the AC unit only. There was second thermostat, that operated the furnace only, mounted in the center bedroom at the rear curb side wall near the corner of the dividing wall that separated the bedroom from the rear bath. That rear thermostat, if I remember correctly, was hidden by the window curtain.
Alan
Old 09-26-2012, 11:11 AM   #5
flyfishrra's Avatar
1983 34' Limited
Wheat Ridge , Colorado
Mine only has one for the furnace. We use the built in one on the AC. Question though. Can a new digital programable thermostat be used in these for the furnace? Just curious since we are full timing and wondered if we could swap it out.
flyfishrra is offline   Reply With Quote
Old 09-26-2012, 12:01 PM   #6
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 11
Yes. I had a hunter digital from Lowes that replaced my furnace thermostat. It was a big improvement.
Bud
Ridgerunner3 is offline   Reply With Quote
Old 09-26-2012, 02:05 PM   #7
KYAirstream's Avatar
Northeastern , Kentucky
Can you say more about how it is a big improvement? I have a digital thermostat for the house, but am curious about the advantage for a trailer?
KYAirstream is offline   Reply With Quote
Old 09-26-2012, 05:52 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I changed mine out for a digital. The big improvement is comfort.
With the original mechanical/spring type there was a large temperature swing between on and off, I'm guessing 10 degrees or more. Now there is about 1 degree swing.
The one I bought at Lowes was around $15 and has a clock in it, which takes 2 AAA batteries that last more than a year.
Just make sure the one you purchase it rated for at least 12v dc.
Alan
Old 09-26-2012, 05:58 PM   #9
Thanks for the information.
Old 09-26-2012, 06:15 PM   #10
2002 25' Safari
Images: 11
Same answer for the improvement when I changed to digital.
Bud
Old 09-26-2012, 11:03 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The thermostat in my '87 Excella is the original mechanical one. It cycles regularly and there is no big swing in temperature. However, I did modify it by adding a small spst switch so that I don't have to move the temperature setting to turn it on and off. The switch was a small toggle spst I bought at Radio Shack.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 09-26-2012, 11:23 PM   #12
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, for me it was the ability to set a certain temperature; [like 66 degrees] With the manual thermostat it was a big guessing game. [too hot, too cold, too medium] I didn't like getting up at 2:00 AM because we were too hot or freezing.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
