09-07-2013, 10:31 AM
2003 30' Classic S/O
Regina
, Saskatchewan
There's a whole lot of shakin' going on....
My husband is quite a big guy, and whenever he is moving about the AS ie cooking or walking from the front to the bathroom, the whole trailer shakes. We have a 30' SO and the stabilizer jacks are down. Any suggestions?
09-07-2013, 12:06 PM
1977 31' Excella 500
West Sacramento
Try using wheel chocks that tighten between the wheels. That helped my problem
09-07-2013, 12:21 PM
1994 30' Excella
Mississauga
, Ontario
Ask him to tiptoe lightly. Just kidding.
Al
Al and Jean
TAC ON-3
09-07-2013, 01:06 PM
1999 34' Excella
Hillsboro
Our 34' shakes when our granddaughters walk. They are small. I am 260#. It moves when I move. My wife's 16# dog makes it shake too. .. Just a bit.
SOBs are same.
So, I tried something. I lifted AS and put jack stands on frame just ahead of front and behind rear axles. Much more stable... Too much hassle.
But, almost zero movement.
With stabilizers on square plastic pads, there is some movement as the pad slides on the plastic. Wood has less tendency to slide. So, the plastic on ground with square of plywood on top gives good pad traction.
No matter what I try, it isn't as stable as a concrete slab. I can live with that. My wife is very sensitive to movements of the AS, but quickly adapted.
Using the "x" clamp between tires will minimize front to rear but not side-side or vertical motion.
Bottom line, most stable was lifting onto jack stands, but few will use because of the hassle. This is also how to store AS for long periods of time. (IMHO).
Peace and Blessings..
Channing
WBCCI# 30676
09-07-2013, 02:36 PM
2014 25' Flying Cloud
Cuddebackville
, New York
Just the other day someone told me that using those jack-like wheel chocks between the wheels makes it noticeably more stabile. I wouldn't really know, I only have one axel.
09-07-2013, 02:58 PM
2007 25' International CCD
San Diego
09-07-2013, 03:21 PM
Cuddebackville
, New York
Yup, those are the things.
2019 Ford Expedition Platinum
09-07-2013, 03:31 PM
1984 34' International
Toronto
, Ontario
Best chocks on the market, these. I've got the Hensley branded version at a sale, otherwise identical.
I've never really noticed much movement in our 34', even without the stabilizers down. And I am a tall guy, at 6'7".
Maybe we're not that sensitive to it.
09-07-2013, 04:30 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
Not a lot you CAN do, really. When you think about it, you've got a jack on the tongue. You've got stabilizer jacks at the rear. But in the middle, you've got springs. The trailer will flex in the middle even if the ends are rock solid.
X-chocks will help, somewhat, by taking out any movement of the tires. But you won't be able to completely damp out the flexing action.
09-07-2013, 04:45 PM
1999 34' Excella
Hillsboro
Hey... Chock front and rear on both sides. Wrap a ratchet tie down around then to keep pressure then see if that helps on single.
Channing
WBCCI# 30676
09-07-2013, 05:52 PM
2012 30' International
Bad Axe
, Michigan
Originally Posted by ginsun88
Yep. Those chocks do a good job of stopping movement.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
09-07-2013, 06:04 PM
2012 28' International
Olympia
I ordered two yesterday. I had one and it worked great, until I drove off and left it at the KOA in Bozeman.
Should take me twice as long to lose two.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
09-07-2013, 06:13 PM
2012 25' Flying Cloud
Battle Lake
Yes, the X-Chocks help a lot.
doug
