12-11-2008, 06:13 PM
1970 27' Overlander
Jacksonville
The Fire
Last Tuesday night we had a fire inside our Airstream 1970 International Land Yacth. It did a lot of damage in the front section. Has anyone replaced the inside skins and where can we get a kitchen window and a front dome?
Thanks for any and all help.
12-11-2008, 06:26 PM
1993 34' Limited
Melbourne Florida
, Springfield Ohio
I trust there were no injuries. Sorry for the loss.
12-11-2008, 06:37 PM
1984 29' Sovereign
Savannah
, Missouri
I, likewise, am trustful that not one person was injured as a result.
Sorry for your unit's losses..
As painful as it may be, could you share more details and, photos of the damages?
ciao
53FC
WBCCI 5292 AIR 807
NEU #64
New England Unit
12-11-2008, 07:05 PM
1956 22' Flying Cloud
1956 16' Bubble
1947 22' Liner
Valley View
just curious
Thank goodness your OK. It sounds like a major fire at the entrance area.
Were you in the Airstream when it happened? Smoke detector? Fire extinguisher? I always preach to have an escape plan....... , particularly in a front fire. Can you ALL get out the back? If not, can you fight the fire with whats available so you can get to the door?
12-11-2008, 07:21 PM
1985 27' Sovereign
Defiance
, Ohio
Wow! That's two fires in two days! Sorry for yuor loss galscotty, hope everything works out ok.
12-11-2008, 08:16 PM
1994 34' Excella
Mount Vernon
, Kentucky
Sorry about the loss as well. I believe Inland RV may have the replacement domes. Not sure about the replacement glass. Look up Aircraft Spruce on the internet. They sale all kinds of aluminum sheeting and can ship it reasonably through UPS. I did some reskinning of my unit last winter. It is some work, but not overly difficult. Best of wishes.
12-11-2008, 08:27 PM
2008 27' International CCD FB
Bothell
So sorry for the loss... hopeful that no one was hurt...
HUGS!
/Lois
Air # 20467
WBCCI #4018
Just call us Jean & Bill :-)
12-11-2008, 08:51 PM
2006 19' Safari SE
Tucson
That's a couple of Airstream fires in the last week...glad you are OK and that you gt it all squared away soon... Do you know the cause yet?
12-11-2008, 09:51 PM
Corona
We can help you with the parts you need, as well with instructions.
12-12-2008, 09:36 AM
"Bess" Full Timers
Suquamish
It would be very helpfull to all of us to know the causes of these fires; can you post a pic
of the damaged area? Glad you're o.k.
"A settled wisdom, plus the itch to be elsewhere"
12-12-2008, 01:22 PM
Vagabond
1973 31' Sovereign
Fort Meade Md. RV park slot 8!!
, Motorsports Photographer
I would be nice to see pic. As one who is in the same spot as you!!! Did you have Ins. How bad Is the smoke damage?? I would pull all fabrics out of the trailer right away. I will need both end caps and new window coverings end to end and more to come. Im up to 50+ loads of Landry and front inside skin for starters!!! I wish you luck!!!!!!!!!! If my baby was not polished I would just start over. Its a pain In the ass and a big hart ake to deal with I have yet to come to terms with it, as It was my home!!!!!!! I will think about you in my prayers, God bless!!!!!!!!!!! DIMMER
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
12-12-2008, 05:33 PM
1970 27' Overlander
Jacksonville
Cause of the fire.
My husband was disconnecting the big gas oven and he had shut off the gas, but there must have been some in the pipes and went he went out to get some paint "boom" something ignighted the gas! There also was some empty spray paint cans in the trailer on the sink. He had just finished redoing the inside of the trailer and started the polishing of the outside. We had not even taken it out yet. So now he wants to redo it a little differently. i am posting pictures.
Nona
12-12-2008, 05:52 PM
1970 27' Overlander
Jacksonville
I just posted some pictures. I got a little confused as where to post them, but the keywords are fire and 1970 Airstream.
Nona
12-12-2008, 06:28 PM
1970 27' Overlander
Jacksonville
Husband explained what happened
My husband wants me to explain it better. Gas wall oven was removed as it was not going to be repaired and we needed space. Disconnected with no problems shut off valve at oven was turned off and I was going to pull copper gas line down below countertop and cap line. Shut off gas at outside tanks and was preparing to remove shut off valve so I opened shut off valve and heard sight hiss figuring it was bleeding down, I walked outside. Two minutes later I turned to look at the trailer and saw fire from gas line. Nothing was on inside trailer other than overheads and task lighting over sink. I thought there was nothing that could ignight gas. Wrong! Believe the very hot 12 volt exposed task lighting bulb directly over bleeding down gas line was hot enough to ignight gas. I believe propane is lighter than air and will pocket up to exposed bulbs. Try touching your 12 volt light bulbs after extended run time, very hot. Suggest any gas work be done with no exposed lighting.
Joe
| Thread Tools |
| Display Modes |
