Old 12-26-2014, 09:15 AM   #1
2013 25' International
mont st hilaire , Quebec
the fan in my range hood doesn't work !!
I try my range hood and a lot off noise and no action
something need to know befor I use it ???
otherwise if I need to replace the engine where I can find it ???
Try some locate dealer didnt have it or campingwolrd need the part number ??
any test I can make befor I say its over ??
thank you
socool69 is offline   Reply With Quote
Old 12-26-2014, 09:18 AM   #2
SteveH's Avatar
Common Sense , Texas
If the fan motor runs, but does not draw air in, check to insure the little flap on the outside is unclipped allowing it to pass air.
Regards,
Steve
Old 12-26-2014, 09:31 AM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Yeah, what he said.
terryV is offline   Reply With Quote
Old 12-26-2014, 09:46 AM   #4
ok may be it only that let me try it again
Old 12-26-2014, 09:48 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The first time I used the hood fan on my new trailer I had the same noise. Sure enough I forget about the little flap.
MICHAEL
Old 12-27-2014, 12:20 PM   #6
the little flap are open ...
what I can test now ????
Old 12-27-2014, 12:34 PM   #7
SteveH's Avatar
I would take it apart and insure that the fan is actually turning. It could be the squirrel cage blower is loose on the motor shaft, because you said it was making a lot of noise.
Regards,
Steve
Baraldi Range hoods, The Stainless steel Range hood found in 2009 Airstreams AeryCorp Commercial Listings 18 05-10-2016 01:41 PM
Range hood exhaust and monitor panel won't work CSBARRY 1994 - 1996 Excella 0 08-30-2014 04:07 PM
Range Hood Fan cooney Stoves, Ovens & Microwaves 5 07-29-2010 06:29 AM
How to work range hood? altastars Stoves, Ovens & Microwaves 8 05-12-2004 04:37 PM
Loud range hood fan lbrodsky 2001 Safari 5 09-26-2003 06:08 AM
