Old 11-07-2015, 12:15 PM   #1
nickclifford's Avatar
1972 31' Sovereign
felton , California
That darned leak!! Need help from leak experts !!
Coming in from above windows in kitchen and bedroom same side. It's not the window seals or gaskets as I've blasted with hose pipe. I'm wondering if the rail on the roof that runs length of trailer is a potential leak source ? This is a 31' Sov. Bty.
Ac and air vents have fresh sealer.
Pic is of the roof rail.
Thanks in advance ! Click image for larger version
Name:	ImageUploadedByAirstream Forums1446923598.113107.jpg
nickclifford is offline   Reply With Quote
Old 11-07-2015, 12:28 PM   #2
1972 31' Sovereign
felton , California
Name:	ImageUploadedByAirstream Forums1446924503.086181.jpg
Better pic ! Could this rail be a leak source ?
Old 11-07-2015, 12:59 PM   #3
1989 32' Excella
Sharon Springs , New York
While I'm new to AS leak sources(just got our AS), it looks like you could take the rail off and check for corrosion pin-holes behind it. Based on the threads I've read, aluminum pin-hole leaks are quite possible. Other than that, as I'm sure you have, reseal every seam you can find. I saw a thread where leaks can occur behind the belt-line on the AS's of my vintage(80s-early 90s), maybe the rivets/screws holding your rail on could also be an entry point for water and after it seeps in may follow the frame supports to appear not-so-near where it entered the unit. Hope this helps...
Good Luck,
James
Easyrider06 is offline   Reply With Quote
Old 11-07-2015, 01:25 PM   #4
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
One source of roof leaks that show up in strange places is the vent pipes.
They have kits to replace the gaskets (boots around the pipe) I got mine from Inland RV and fixed leaks over the front door and kitchen window.
I never did find the leaks but read on here how the gaskets fixed strange leaks and it fixed mine.
Garry
Old 11-07-2015, 01:26 PM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I've got a rear window leak and have the rear awning. My leak drips down from the inner window frame and runs down the screen. I'm suspecting the awning rail. To do the best caulking job I'm going to have to remove the rear awning from the rail to get at it. I'm going to caulk the top of the rail and the top of the window.
I guess the only sure fire way to pinpoint a leak is to get a pressure test and soap around all the windows awning rails etc to look for bubbles. Otherwise its a shot gun approach. Caulk and then test, repeat until no leak detected. The leak could be coming from a roof vent and running down the inside walls. Very frustrating.
Kelvin
Old 11-07-2015, 01:32 PM   #6
1972 31' Sovereign
felton , California
Kelvin
definitely not the roof vents for me as I just added new caulking ... not the windows themselves as I've literally soaked with a hose pipe and that's with original window gaskets !! it's either the actual roof seams( or that rail .. not even sure why it's there ?
Old 11-07-2015, 01:40 PM   #7
Mission , Texas
Roof vents - how is the weather strip?
Awning rail - is that a rusted screw in the photo?
nrgtrakr is offline   Reply With Quote
Old 11-07-2015, 03:15 PM   #8
1972 31' Sovereign
felton , California
roof vents are fully sealed, a/c has new sealant around seems too. What is the weather strip?
i've removed rusted screw and added some sealer. Main source of water is entering via window frame in bedroom & to lesser extent over kitchen sink.
thinking about running a think line of caulking along the awning rail ? or removing and then re revet adding some sealant in the rivet hole?
thanks for the advice
Old 11-07-2015, 03:23 PM   #9
Central , Mississippi
A pal of mine chased a similar leak for weeks. The screw that goes in the end of the rail had been drilled all the way thru the shell but the screw only went thru the outer part of the rail. The only way he found it was by a pressure test.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-07-2015, 04:25 PM   #10
Mission , Texas
There probably should be a weather strip on the top edge of the vent flange facing skywards so that when the vent is closed the lid seals shut against it preventing air from exiting and water from entering.
Ours leaked at the window frames also.
I'd replace the rusty screw with an Olympic rivet slathered in TremPro before installing. The rail could save some work if you replace the awning.
Old 11-07-2015, 04:56 PM   #11
KAYAKAMPERS's Avatar
1966 26' Overlander
Stone Mountain , Georgia
Having a similar problem with my back window area. If and when this Georgia weather ever dries out, I plan to replace the window seal and seal every seam I can find. The problem I have is that water drips are going past the window and dripping inside the rear inspection cover and onto the rear part of the floor. With the rain, all I am doing now is catching and dumping it.....and waiting for dry weather.
_______________________________
Beth Wallace & Chris Sanor
1966 26' Overlander International
Towed by 2016 Ford F-150
Tin Can Tourist
TAC #GA-27
AIR #34930
KAYAKAMPERS is offline   Reply With Quote
Old 11-07-2015, 05:11 PM   #12
Mission , Texas
There is a product for sealing aluminum gutter seams that supposedly can be used on wet surfaces. Haven't heard many talk about it.
Old 11-07-2015, 08:35 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Properly seal roof vents! Do NOT use silicone! Work on the vents first. If still leaking g, work on that rail...
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-07-2015, 08:38 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Consider getting a "leak test".. They pressurize inside then put soap solution on exterior.. Watch for bubbles! If you pressurize yourself, get a gallon of cheap "soap bubbles"'from a Dollar store and use it.. Generates best bubbles!
Channing
WBCCI# 30676
Need help from the vintage experts ... Got Briards Vintage Kin 3 06-29-2011 10:42 PM
The Darned Flap Broke Off!! centennialman Electrical - Systems, Generators, Batteries & Solar 7 02-21-2009 05:07 PM
PC Experts--I need help Minnie's Mate Off Topic Forum 15 11-17-2008 01:33 PM
Airstream weights: Can't find that darned link eubank Tow Vehicles 3 03-25-2007 07:11 PM
Darned water spots! Charcigar Cleaning, Stripping & Polishing 6 07-30-2002 02:29 PM
