Old 12-06-2007, 01:55 PM   #15
crowldawg's Avatar
1966 20' Globetrotter
Orient , New York
I've had my '66 G T plug into the garage since I aquired it in sept. 20 amp breaker .I even used the ac onc or twice in sept,I have a 10 ga extention cord
crowldawg is offline   Reply With Quote
Old 01-13-2008, 11:51 AM   #16
1974 Argosy 20
Burlington , Ontario
With the air on you will be stressing the circuit to it's possible limit. Play on the safe side and you will not regret it. How often I have seen and heard of "Well I or he did it and got away with it. so you go for the cheap , and risk the loss of the unit and possible fire.
Maybe you have an extra AC unit or the money to experiment.
As the load increases , so does the heat and deterioration.
Rae
ve3czn is offline   Reply With Quote
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
50 and 30 amp shore power tinbender Electrical - Systems, Generators, Batteries & Solar 15 06-22-2007 10:33 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Shore power sockets niftypkg Electrical - Systems, Generators, Batteries & Solar 2 02-26-2007 06:35 AM
Power w/o batt. just shore... crazylev On The Road... 8 11-12-2004 04:14 PM
