Old 07-28-2012, 06:01 PM   #1
flyslinger's Avatar
2003 22' International
Morrison , Colorado
Test button on converter panel.
I have a circuit breaker on the converter panel that is tripped and will not reset. The breaker that is tripped is the one right above the TEST button, and it is the circuit for the galley and dinette outlets, and the refer. Does anyone know what this test button does, it is in all the way and does nothing when I try pushing on it?
flyslinger is offline   Reply With Quote
Old 07-28-2012, 06:31 PM   #2
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Gfci ???
I can't be sure without seeing it but it sounds like you are describing the GFCI circuit breaker. It usually has a "test/reset" button. It can be touchy and is not an uncommon situation. Make sure that you turn the circuit breaker all the way off and then all the way back on. If you just flipped it in the off direction it may not have gone fully into the off position. If not, it won't reset. Worth another try.....
Good luck..... tb
tinbender is offline   Reply With Quote
Old 07-29-2012, 06:47 AM   #3
flyslinger's Avatar
Morrison , Colorado
Much obliged tb ...
Yeah I think you are right about it being a gfci circuit but it will not reset when turned off and they on. The test button is stuck in and will not pop back out.
flyslinger
Old 07-29-2012, 07:14 AM   #4
richinny's Avatar
2011 34' Classic
i think the button will do that if there is no power to it. do you have a tester to check the power to the breaker?
Ricky
Old 07-29-2012, 02:01 PM   #5
flyslinger's Avatar
Morrison , Colorado
No tester ... I will try to borrow one ... much obliged for the input.
