Old 07-14-2016, 12:22 PM   #15
dznf0g's Avatar
Oswego , Illinois
I agree with Lew, that carb cleaner is great for prep....BUT, it can attack some paints, coatings and plastics if you are not very careful with it. There are two other products which won't harm paints nor attack plastics/rubber. BrakeClean and my favorite final prep chemical for many projects. PrepSol (or other paint prep brands). It is designed as the last wipe down before and between paint coats for cars etc. IMO, it is the best FINAL prep chemical, but doesn't clean a quantity of oxidation or dirt well.
My methodology is BrakeClean then a final wipe down with PrepSol.
-Rich-
Old 07-14-2016, 01:45 PM   #16
DFlores's Avatar
1968 22' Safari
Originally Posted by hippiechick View Post
Got it. Prep with WD40, use good tape, pull tape immediately. Thanks so much. Glad it was only one seam.
Do not prep with WD40, I use it to work bead of Tempro after I put it on
Sent from my iPhone
David & Diane
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 07-15-2016, 02:34 PM   #17
hippiechick's Avatar
1966 24' Tradewind
versailles , Kentucky
Originally Posted by DavidsonOverlander View Post
I don't think this is the cause of the problem you described here, but keep in mind that some TremPro products have a shelf life. For TremPro 635 it's one year. I found this out the hard way when I used some TremPro 635 that was a couple of years old to install vista view windows and had to reinstall them.
Actually the age could be part of the issue. We've had the product for quite some time. I wasn't aware that it had a shelf life. Thanks.
hippiechick is offline   Reply With Quote
Old 07-15-2016, 03:25 PM   #18
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
There should be a date code stamped on the tube. I think it's on the metal part inside the bottom of the tube.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-16-2016, 08:57 PM   #19
1966 24' Tradewind
Date code 2012!!!! Ordered some new tubes today.
Polishing... When or what stage do you use the Tempro to seal around windows Shawnna Cleaning, Stripping & Polishing 8 08-29-2014 11:45 PM
Storing open Tempro? reddoor Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 08-15-2011 06:15 AM
Tempro/Vulkem under c channel? Becky B. Repairing/Replacing Floor &/or Frame 2 05-23-2011 05:43 AM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Disaster Weekend davidz71 Our Community 11 07-03-2002 04:27 PM
