Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 04-15-2008, 04:21 PM   #1
lisa.bivens
Profile:  2008 25' Safari SS SE
Memphis , Tennessee
tar removal?
I am having a hard time finding kerosene to remove small amounts of tar on AS. Any other suggestions that will not hurt SSE 08' finish? Thank you.
lisa.bivens is offline   Reply With Quote
Old 04-15-2008, 04:31 PM   #2
2airishuman
2airishuman's Avatar
Profile:
hi lisa...
i'm guessing wd-40 will have the most user support here...
and it does work.
whatever solvent is used be careful about 'rubbing' because road tar often has sand or other abrasives in it...
and the stuff can scratch the clearcoat....
i use 3m remover or sd-20 noted in these posts...
http://www.airforums.com/forums/208430-post2.html
http://www.airforums.com/forums/413798-post7.html
widely available...
3M...
this shouldn't apply to a NEW trailer,
but for really OLD DRIED HARD tar and oversprays i use an automitive 'clay bar'...
if solvents don't dissolve it first...
cheers
2air
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 04-15-2008, 04:57 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Method counts too
Originally Posted by 2airishuman
...i'm guessing wd-40 will have the most user support here...
and it does work....
2air is not guessing.
For tough tar spots, take a paper towel & fold it twice to make it a quarter of its size.
Tape the folded paper towel over the stubborn spot.
Spray the folded paper towel with WD-40 until saturated.
LEAVE IT ALONE for a couple of hours.
THEN, remove the paper towel and assess. Repeat as necessary, and rubbing will not be required.
I use a similar technique for my motorcyle helmet's face-shields for bug splatters (water instead of WD40) for outstanding results.
Tom
Old 04-15-2008, 05:06 PM   #4
centennialman
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
I concur..........WD-40 is the best for tar removal.
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 04-15-2008, 05:09 PM   #5
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
On the "few" occasions that I have tracked grease onto MY WIFES white carpet, WD40 always removes it before she gets home from work, thus saving my Bacon.
Old 04-15-2008, 07:07 PM   #6
NevadaGeo
Profile:  1978 31' Excella 500
Genoa , Nevada
Its scary how ordinary Mayonaise will dissolve just about any tar and pitch.
NevadaGeo is offline   Reply With Quote
Old 04-15-2008, 08:53 PM   #7
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I use old fashioned liquid lighter fluid (naptha). it will disolve tar or just about any glue without damaging any finish.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 04-15-2008, 10:44 PM   #8
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
We used ordinary bleach and a brush to get tar balls off of our shoes after walking on the Gulf coast...
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 04-16-2008, 03:50 PM   #9
strmstr69
strmstr69's Avatar
Profile:  1976 Argosy 26
Auburn , Washington
Turtle Wax Bug and Tar Remover.
Used it to remove glue and tar for years, works great. Just put some on the tar and let it sit for a few minutes and then wipe carefully. Repeat as needed.
Dan and Sherry W.
strmstr69 is offline   Reply With Quote
Old 04-19-2008, 09:22 AM   #10
Rae
Rae
Profile:  1974 Argosy 22
Burlington , Ontario
Try the liquid paint solvent (thinners). (Varsole) Found at any American hardware store. It is Coal oil or kerosene.
Be sure to warm it to facilitate easier removal.
Allow sometime with cloth soaked in kerosene applkied against stain to let it desolve the tar.
It will not harm your finish.
Rae
Rae is offline   Reply With Quote
Old 04-21-2008, 08:21 PM   #11
gaylejoe
gaylejoe's Avatar
Profile:  2003 25' Safari
St. Hedwig , Texas
I've always had good results using a little diesel on the spots.
gaylejoe is offline   Reply With Quote
Old 04-21-2008, 11:55 PM   #12
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Brian
Hi, lighter fluid has always been my favorite for removeing sticky things without paint damage Etc. Tar, Body side mouldings, and padded dash pads on two 1959 Galaxies.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 07-08-2008, 11:30 PM   #13
63Silver
63Silver's Avatar
Profile:  1963 28' Ambassador
Smiths Grove , Kentucky
Images: 34
I have packing tape ALL the way around my airstream ( very old) , do you think Lighter fluid will work and are you talking about the lighter fluid in the old fashion cigarette lighters or the kind you use to light charcoal briquettes?
63silver
63Silver is offline   Reply With Quote
Old 07-09-2008, 12:21 AM   #14
ROBERTSUNRUS
Images: 18
63silver
Hi, lighter fluid, like you use to refill a Zippo Lighter.
2005 Safari 25-B
Clearcoat Removal equigley Cleaning, Stripping & Polishing 23 04-27-2008 11:35 AM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 02:00 PM
Bathroom Removal Keyholeren Cabinets, Counter Tops & Furnishings 6 11-06-2004 08:12 AM
Jack removal Over59 Jacks, Stabilizers, Lifting and Leveling 11 06-24-2004 01:04 AM
A/C removal Rob Furnaces, Heaters, Fireplaces & Air Conditioning 14 04-22-2003 07:53 PM
