Old 12-01-2012, 09:14 PM   #1
DWH
1961 22' Spaceliner
Clinton , Washington
Tank locations
I am in the process of full restoration and working on the frame. I am adding a grey and black tank and have mocked up where I was planning on putting them. They are set about 12" behind the axle.
Do you see any problem with this location?
-Dale
http://1961toaster.blogspot.com/
DWH is offline   Reply With Quote
Old 12-02-2012, 01:41 AM   #2
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
It looks good, based on your pictures it seams like you could even move the tanks closer to the axle, keeping in mind We are not sure where the drains, vent stacks connect to the top/side of tanks. The rule that I like too follow is the closer the tanks can be to the Axle the better, so that the weight is balanced from front to back.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 12-02-2012, 08:19 AM   #3
2003 25' Safari
Riverside , California
Being close to the axle is also going to help with ground clearance if you are like me and tow into sketchy areas off the beaten path
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 12-02-2012, 08:28 AM   #4
DWH
1961 22' Spaceliner
Thanks for the input. I could slide them even more forward so they would be up against the crossmember just behind the axle, but I was afraid it would make it difficult to access he rear spring hangers. I'll have to do some more testing.
-Dale
