Old 12-17-2014, 03:40 PM   #29
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
"i think these 'arms' are meant to eliminate fore-aft rocking but if that is true, your exterior sheet metal is going to take a beating."
The arms are attached through the shell into the aluminum frame supporting the shell. No beating at all in thousands of towing miles throughout the country since installing our rack.
You might consider adding them to your setup to resist the rotational forces caused by your bikes being mounted well behind the frame and bumper.
Doug and Cheryl
Old 12-17-2014, 03:55 PM   #30
gpt
2014 25' FB Flying Cloud
sequim , Washington
thanks for clarifying that for me.
gpt is offline   Reply With Quote
Old 12-17-2014, 04:32 PM   #31
1966 20' Globetrotter
2008 23' International
Cedar Falls , Iowa
Send a message via AIM to hahnstead
I might add that if you have more than one Airstream, having the bikes on the front of your TV means you don't need a bike rack on each of your Airstreams.
Hahnstead Airstream Park
hahnstead is offline   Reply With Quote
Old 12-17-2014, 05:32 PM   #32
2011 23' Flying Cloud
Durango , Colorado
Nice job by the OP on a receiver mount. So much misunderstanding and misinformation on this topic, without clarity from Airstream. Monocoque vs semi-monocoque is a significant difference. Old chassis design vs newer models. No mystique to the overpriced Fiamma rack - it is clearly supported by the C beams and stabilized by attachment (with sheet metal screws) to the body. Airstream is simply negligent in not providing a receiver mount with clearly stated load capacity.
This Engineer took a different approach, extending the C beams by 12" with a "swim platform" on which I can carry a bike or other light cargo. Moving the bumper back 12" added crash protection to the rear end. 100 lbs on the tail decreased the tongue weight on my 2011 FC23FB from 14% to 13%. No noticeable change in towing characteristics in over 10,000 miles and all sorts of roads. Click image for larger version
Name:	ImageUploadedByAirstream Forums1418862673.852894.jpg
ID:	228814. No, the grandkids don't ride back there😉
Name:	ImageUploadedByAirstream Forums1418862368.563139.jpg
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Old 12-17-2014, 06:42 PM   #33
Happy Wonderer
B_Pi's Avatar
1997 25' Safari
Box Elder , South Dakota
I like the idea of the rack and thought one in rear would be nice too. Hadn't heard about frame separations either.
We have carried two mountain bikes with us since we left 7,500 miles ago. We carry them in the trailer and it is a matter of 2 minutes to load and unload them at each end of a stay.
At this point, I have no intention of an outside rack because the bikes stay dry, safe and theft proof inside. What's not to like?
Freethinkers are those who are willing to use their minds without prejudice and without fearing to understand things that clash with their own customs, privileges, or beliefs. This state of mind is not common, but it is essential for right thinking...
― Leo Tolstoy
B_Pi is offline   Reply With Quote
Old 12-17-2014, 06:45 PM   #34
dkottum's Avatar
Imagine a 10 long foot board extending out from the back of the Airstream and attached firmly to the frame. Jump on the end of that board and the board will try to twist (rotate) the frame down away from the shell.
Add support bars from the end of that board to high on the shell. Now when you jump on the end of the board the twist (rotation) trying to separate the frame away from the shell is minimized, maybe eliminated. This is because the shell now supports the end of the board.
As I understand it, that is the logic of the upper support bars on the Airstream bike rack. No mystery to it.
Doug and Cheryl
Old 12-17-2014, 09:19 PM   #35
Ronman's Avatar
2007 27' Safari FB SE
Rancho Murieta , California
This is not helping! ;-) While I do not like the Fiamma application due to the intrusion of the skin and the potential life expectancy of the plastic / rubber pieces, I tend to shy away from this application. Also, if you want to remove the apparatus, it does not look like it would be feasible.
I do like the theory of GPT's application but I heed the warnings of the several experienced Airstreamer's on this thread. So...I will wait for an alternate solution!
Thank you all for your information.
Ron
Ronman is offline   Reply With Quote
Old 12-17-2014, 09:28 PM   #36
SteveH's Avatar
Common Sense , Texas
Our "alternate solution" was simple, folding bikes in the back of the truck. DAHON Bikes:*Espresso D24
Regards,
Steve
Old 12-18-2014, 05:42 AM   #37
Lily&Me's Avatar
Normal , Illinois
Another vote for folding bikes.
Maggie
Lily&Me is online now   Reply With Quote
Old 12-18-2014, 07:29 AM   #38
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I opted for the front receiver from e trailer. Easy install. Practically invisible. Have yet to use it with the bike rack. I do not have the option of carrying inside the Suburban because of all the "stuff". As a potter my wife likes to take her potter's wheel, a hundred pounds of clay, a slab roller. Our WBCCI Unit members like to play in the mud! Our rallies are a blast!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 12-18-2014, 08:23 AM   #39
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
This explanation of how the Fiamma rack works makes perfect sense. Basically, it maintains the integrity of the body/frame connection by placing the same amount of stress on the body AND frame simultaneously.
Bob Martel
WBCCI# 5766
Old 12-18-2014, 08:39 AM   #40
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Presume this is for the front of your tow vehicle?
You mention that you have yet to use it - just a suggestion if you have not already tried this. I would fit the bike rack and bikes just to see if the bikes sit at a good height so as not to interfere with vision. Better to do this in advance rather than on the day you want to leave on a trip!
I used a front mounted receiver/bikerack on our GMC Sierra 1500, and all was well, but when we switched to a Sierra 2500HD, the design of the hitch receiver was much higher at the front of the truck and the bikes were way too high.
I cut down and re-welding the bike rack to suit.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-18-2014, 10:27 AM   #41
gpt
sequim , Washington
hard to believe that sheet metal screws will succeed in '...maintaining the integrity of the body/frame connection...'
i think this was added simply because the design of this bike carrier is not well thought out in the first place. the bolting to the frame would allow considerable fore/aft movement particularly from the perspective of the weight being held up high. so i suspect the arms were added to try and stabilize this movement as opposed to the above statement.
take a look at any bike rack from Yakima and you may be able to see the difference in what i am talking about.
Old 12-18-2014, 10:35 AM   #42
projector's Avatar
1972 23' Safari
NSB , Florida
I took the risk in doing a receiver mount rack, very similar to gpt's. The rack is made by Swagman, it also screws to the receiver and doesn't move. Our axles are back more that usual on the trailer so the rear overhang is relatively very little, like a boat trailer. It almost looks like a 25' with the back cut down and makes for excessive tongue weight. I also did a rear spare tire carrier that I may remove after thinking more about it.
projector is offline   Reply With Quote
Kayaks and bikes jordandvm Off Topic Forum 42 02-26-2009 09:12 PM
Taking a smart car along westernviews On The Road... 24 05-15-2008 11:01 PM
Foldup Bikes campadk Off Topic Forum 29 11-21-2007 08:28 AM
Bikes and Bambi Trevor Davies 1997 - 2004 Bambi 13 12-22-2004 07:07 PM
How Do U Bring Bikes Along? Steve Heywood On The Road... 30 04-06-2004 10:37 PM
