Old 09-25-2014, 11:31 AM   #1
2007 27' Classic FB
Clearwater , Florida
Table repair
We have a 2007 27FB Classic. The table fits loosely and has been coming off the wall on recent trips. I will attempt to bend the clips for a tighter fit. Is there a better fix for this?
bross is offline   Reply With Quote
Old 09-25-2014, 11:48 AM   #2
The fix is not the issue, but the cause is.
The following is a list of things that can cause that table leg to give up.
Lack of proper running gear balance.
Bent wheel.
Excessive rated hitch bars.
Excessive rated tow vehicle.
And lastly, especially on older trailers or if one has not moved in 2 to 3 years, bad rubber rods within the axle tube.
To check the axles out, pull one wheel up on a couple of 2 x 6's. The other wheel should drop about 3 inches. If not, then you should further check the axles out. Is the torsion arm, as it goes rearward, going down hill, or level with the frame, or going uphill as it goes rearward?
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
shop repair of 1970s rear frame separation (non elephant ears repair) RV shop review simonhanbury Repairing/Replacing Floor &/or Frame 49 06-24-2008 09:16 AM
falling table leaf of credenza fold-away table Fenghuang Cabinets, Counter Tops & Furnishings 3 02-13-2007 10:27 AM
folding table leg repair help..... Chilao Cabinets, Counter Tops & Furnishings 2 06-27-2005 09:58 PM
