Old 10-09-2016, 09:48 AM   #1
Pat Cassity's Avatar
2015 27' FB International
Montgomery , Texas
Table Leg Dilemma
Earlier this year, a tech at an Airstream dealer dropped my table to the floor while attempting to repair the broken bracket on the subwoofer of my 2015 27FB International. The fall to the floor cracked the plastic foot at the bottom of the table leg. It also broke the inside of the foot that allows the screw foot to adjust the leg length. The dealer ordered another leg but the leg with the screw foot is no longer available from AS. The new legs don't have the screw adjustment and are approximately 2"longer than the original leg with the foot adjustment at its longest length. When I returned to have the leg installed, the dealer realized that this leg wasn't going to work but didn't have a solution. They promised to contact AS for a solution. In the meantime, the service manager at another dealer has informed me that Airstream's solution for this is to remove the plastic end cap on the new leg and cut the new leg to the correct length. (The screw adjustment is not part of the new legs) .I have attached a picture of the leg with the foot fully extended. However, it won't stay like this. The slightest movement causes the screw foot to push up into the leg, lowering the front end of the table by about 2". I would love to be able to find the plastic foot to screw into my leg but I was wondering if anyone out there might have a solution other than installing a new leg that has been cut to fit. Thanks!
Name:	ImageUploadedByAirstream Forums1476027436.574805.jpg
Retirement! Every day's a Saturday and Monday's no longer exist!
Pat Cassity is offline   Reply With Quote
Old 10-09-2016, 10:04 AM   #2
FCStreamer's Avatar
2014 30' Flying Cloud
I had to cut mine to fit.
http://www.ourflyingcloud.com/2016/08/fixed-table.html
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 10-09-2016, 10:20 AM   #3
2016 25' International
Deerfield , Massachusetts
A lot of furniture gets adjustable feet like this with just a hole drilled in the bottom of the foot and a bolt glued in place to receive the foot.
In that vein, my homemade solution would be to cut a piece of wood that fits inside the pipe (I'd look for a hole saw of the same size, but you could do it with a jigsaw...), glue the appropriate sized bolt inside (another hold drilled in) the center of the piece of wood, and the epoxy the whole thing inside the leg.
thiel is offline   Reply With Quote
Old 10-09-2016, 10:59 AM   #4
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
It sounds like the threads in the plastic piece have been stripped. If the plastic piece is thick enough, maybe a helicoil can be installed. A machine shop can do this fairly cheaply if they have the correct size helicoil. If this isn't an option, maybe just run a nut down the threaded rod portion of the foot, and then the nut can rest against the plastic and hold the table in position. Hope this helps. Mike
Mike S. is offline   Reply With Quote
Old 10-09-2016, 06:02 PM   #5
Montgomery , Texas
Thanks guys! You have certainly given some ideas. The threaded area inside the foot, is in fact the problem but not because it's stripped but instead because it broke loose from the foot when it was originally dropped. Based on your suggestions I may be able to attach (glue) a bolt to the inside of the foot where the threaded piece of plastic was originally attached.
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Drop down table leg Safari Tim Cabinets, Counter Tops & Furnishings 2 06-22-2007 05:51 PM
folding table leg repair help..... Chilao Cabinets, Counter Tops & Furnishings 2 06-27-2005 09:58 PM
