Old 07-23-2011, 10:08 AM   #1
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
Unhappy Sweat forming inside closet
Hi, I was just in the camper searching for the water pump and found it and a potential problem!
In the cedar closet, on the inside wall - bedroom side - there were droplets of water! YIKES! These were random and I wiped it down with a paper towel - it appears to have been doing this for a while because a bracket below had rusty screws. I checked the wiped area about 10 min later and it was back - hence I think it is sweating.
The weather here has been torrid and humid - came home on Wed from a 3 day camping trip where we were running the AC full time and kept it quite cold in the camper for the dogs. It rained last night and this morning - I have the roof vents open (Max Air covers) and the North side windows cracked open (same side as the offending closet) just using the locks in the up position to hold the windows open about 1/4".
Any thoughts on this? The camper was pressure tested at the factory last year - doesn't seem to be sopping under - damp, yes. Should I put a dehumidifier in there?
palmtreegirl is offline   Reply With Quote
Old 07-23-2011, 10:52 AM   #2
Check the sewer vent pipe cover gaskets. They only last 2 to 3 years.
Closet flange and new cork floor. desertair27 Sinks, Showers & Toilets 3 06-17-2011 04:10 PM
Its raining inside the AS Snedwid On The Road... 6 06-09-2011 08:51 AM
Dust accumulation inside AC... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-06-2011 05:32 AM
Need Caravel closet pics......... funhouse Sinks, Showers & Toilets 6 05-30-2011 06:29 AM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
