Old 01-29-2016, 07:21 PM   #15
1998 30' Excella 1000
Livingston , Texas
Originally Posted by markdoane View Post
That's what I thought too. Until I burned up the AC at a mom & pop RV park in Forsyth MT.
In cases like that, it's usually low voltage that is the problem. Basic surge protection devices often do not monitor for that condition. You need the more advanced models, or an inexpensive plug-in volt meter that you keep an eye on when the power is suspect.
Siegmann is offline   Reply With Quote
Old 01-29-2016, 10:21 PM   #16
2007 22' International CCD
True that. A low voltage cut-off will save a lot of trouble more times than a surge protector. I know our original A/C died from low voltage over a long period. Built-in management system including low voltage and surge is the next new improvement, after the new tankless hot water, the ProPride, and a better 3-stage converter that we installed already.
KE4GNK/AE
Old 05-30-2016, 02:35 PM   #17
www.streamingairheads.com
streamingairheads's Avatar
Gettysburg , Pennsylvania
Keeping Surge Protector Plugged In?
We have an external Progressive Industries surge protector but it doesn't want to say plugged in at the pole. Curious, how do folks handle this? It seems to heavy to stay plugged in. Thanks!
streamingairheads is offline   Reply With Quote
Old 05-30-2016, 03:27 PM   #18
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
I carry a small block of wood and an adjustable bungee cord. If the Progressive seems to want to fall out, put the block on the back of the plug and bungee it. This seems to be a problem only on older pedestals where the plug is somewhat worn.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
