Old 12-16-2015, 09:20 AM   #1
2016 25' Flying Cloud
Holly Springs , Mississippi
Supplemental Transmission Cooler?
A couple of RV friends have suggested I need to add another transmission oil cooler to my tow vehicle. What do you suggest? Here are my facts:
Trailer is 25' FC. TV is F-150, 3.5L, 3.55 axle, Supercrew. It already has a transmission cooler that's about 2 feet long and 3" high. This appears to be the common size cooler that's currently on F-150's with the max. towing package.
So will I need a supplemental cooler, or perhaps a bigger one to replace the existing xmission cooler?
(Edited to add: My truck does have a transmission oil temperature gauge.)
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 12-16-2015, 09:34 AM   #2
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
Does your truck have a setting in the display to show you transmission temperature? If so, then just monitor it while you are towing. If the transmission is heating up when you are towing (I would say regularly hitting 200) then add another auxiliary unit. If not, then you should be fine. I would do some research to see what people agree is "too hot" for your transmission fluid in your truck though. 200F is just a number I remember from some past research I did.
Echelon73 is offline   Reply With Quote
Old 12-16-2015, 09:48 AM   #3
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
You do not need to upgrade your transmission cooler.
Old 12-16-2015, 09:57 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Wiwd.....
.......FIRST INSTALL....the added capacity will work to control temps.
On our first Burb W/O a OEM Temp gauge....
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-16-2015, 10:09 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I wouldn't worry about 210 degrees, your engine is that or more, when it gets to 240 degrees just back off for a bit....
Old 12-16-2015, 01:00 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Your friends may be basing their advice on experience towing much less aerodynamic, higher profile trailers than your Airstream. Airstream claims they tow 20% easier than the others.
You will have no issues with the transmission overheating based on our experience with two different 1/2 ton trucks pulling our 25' Airstream all over the country many times. IF you do on some long, steep grade in very hot weather with a strong headwind, just back off the speed a little to greatly reduce the wind resistance.
Doug and Cheryl
Old 12-16-2015, 02:00 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
My transmission guy does not like 200 or higher for any length of time. Hard on original equipment seals.
Mine was going over 200 on hills so I added a Tru-Cool 4590. Never over175 now. Cheap insurance.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-16-2015, 02:57 PM   #8
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Bob
The ZF transmission in the F150 (& many other vehicles) does not generate very much heat because it is designed to have the torque convertor locked up almost always so in effect it generates about the same heat as a manual transmission most of the time. The only time it is unlocked is a very low speeds. You would get it the hottest when backing up a steep hill very slow into a campsite repeatedly or something such as being stuck in the mud.
I would change the fluid every 30-40,000 miles and I don't think you will ever have an issue. I would suggest using the ZF fluid for the transmission. The expert on that is California Transmisison Specialties.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 12-16-2015, 07:25 PM   #9
Thanks to all of you who replied. Your comments are really useful.
This forum rocks!
2016 FC 25' FB twin
Old 12-16-2015, 07:39 PM   #10
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I like the idea of great filtration and great cooling for the transmission and the engine oil. Extra of both is indeed cheap insurance.
(Thank you, ROBERT CROSS, for reminding me that I need to order that transmission filter kit.)
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-16-2015, 09:40 PM   #11
Moflash's Avatar
Before you rush out and add this additional transmission filter on your newer computer controlled transmission tow vehicle check with a qualified service tech for your make and model.
The transmission you have already has a filtration system and the likelihood of it needing a additional filter is not likely as it is a completely sealed closed loop system.
Automatic transmission fluid is changed at regular mileage intervals due to the lubricating properties of the fluid breaking down over time (miles driven)and not because of dirt and debris forming or entering the system.
In this case you may do more damage than good.Your new vehicle warranty may also be in jeopardy if a transmission issue arises.
The same goes for adding a additional trans cooler.
Old 12-16-2015, 10:59 PM   #12
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Also use a good quality synthetic transmission fluid and have it serviced (power flushed and replace the fluid) every 50,000 miles.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 12-16-2015, 11:24 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
So will I need a supplemental cooler, or perhaps a bigger one to replace the existing transmission cooler?
Hi, No, absolutely not, unless you are towing a heavier trailer than your truck was rated for. [then you will have more problems than a added on trans cooler could help with] Your truck was designed to handle the rated specs without any modifications needed. Hitch up, put it in Tow Haul mode, and go.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-18-2015, 11:10 AM   #14
I wonder if at least the later model F-150's have a thermostat on the transmission coolers or perhaps the transmissions themselves. Mine seems to run at 190dF, no matter the outside temperature. With a trailer behind it I'd suspect it may creep up some more, but that's yet to be determined.
2016 FC 25' FB twin
Supplemental heaters and furnace setting KYAirstream Furnaces, Heaters, Fireplaces & Air Conditioning 31 01-10-2012 10:57 PM
Opinion please, on transmission cooler.. kidsgone Tow Vehicles 7 01-30-2010 10:50 PM
Transmission cooler 2008 Suburban. adonh Tow Vehicles 39 09-02-2008 10:25 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 10:37 AM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
