Old 12-19-2015, 07:16 AM   #15
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by Bob662 View Post
I wonder if at least the later model F-150's have a thermostat on the transmission coolers or perhaps the transmissions themselves. Mine seems to run at 190dF, no matter the outside temperature. With a trailer behind it I'd suspect it may creep up some more, but that's yet to be determined.
Bob,
Most trans coolers will have a by-pass for cold Weather start-ups, just like engine oil, you want the fluid to warm up as quickly as possible. (start & let idle not recommended, (start,oil pressure=drive.)
190* is fine, critical breakout on our Burb is 275*, limp-mode is around 270* steady for 5min.
Ck your vehicle owners manual......
I'm quite sure the Ford Powertrain Control Module is similar and will engage "limp" to help prevent damage.
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Supplemental heaters and furnace setting KYAirstream Furnaces, Heaters, Fireplaces & Air Conditioning 31 01-10-2012 10:57 PM
Opinion please, on transmission cooler.. kidsgone Tow Vehicles 7 01-30-2010 10:50 PM
Transmission cooler 2008 Suburban. adonh Tow Vehicles 39 09-02-2008 10:25 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 10:37 AM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
