12-01-2012, 12:37 PM
Austin
Super glue?
We're at the beach and just noticed that some strip came loose, at the front rock guard.
It seems that it's glued in there normally. Can I just use super glue or should I use something else?
12-01-2012, 01:50 PM
Biloxi
, Mississippi
You certainly can give it a try.
MICHAEL
12-01-2012, 01:59 PM
1966 24' Tradewind
Placerville
Yes try the SG gel.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
12-01-2012, 08:48 PM
2006 19' Safari SE
Tucson
It is normally held in place with double sided tape, but it has to be strong tape to withstand the exposure to the elements... we had to re-attached a section of ours that came loose...tried several tapes and finally had success with 3M exterior double-faced tape made for attaching exterior signs, etc, and it is the same width as the track the strip fits into. It's not going anywhere now.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
12-01-2012, 09:31 PM
Salem
, Oregon
Hi, 3M double sided tape. The black or dark grey one. Same tape that cars use to hold their body side mouldings on with.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-02-2012, 07:59 AM
Overland Adventurer
2009 34' Panamerica
Telluride
It is originally stick on with the 3M body molding tape. WALMART Carey's it in the auto depth near the body work stuff. Like4$ a roll. Clean off the old as the new will not stick to itself.
12-02-2012, 04:38 PM
2014 25' Flying Cloud
Cuddebackville
, New York
So according to that video Airstream ought to give up on rivets. Stick the whole thing together and eliminate a lot of sources of leaks.
Would I get one, two, or three "strips" instead of rivets for posting here?
12-02-2012, 04:55 PM
2012 28' International
Olympia
I agree, tape it all together, Maybe rivet decals to keep the classic look.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
12-02-2012, 08:51 PM
1966 24' Tradewind
Placerville
Yes...I forgot about that tape. It's what the body shop used to replace my trim after my Buick's complete down to the metal restoration. Only one minor problem....'they' stuck the namplate on one fender 1" lower than on the other side. I'm the only one so far that noticed that...driving me even though one would have to circle the car very fast to notice it. It's stuck on REALLY good.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
12-02-2012, 09:36 PM
Salem
, Oregon
Originally Posted by FreshAir
Yes...I forgot about that tape. It's what the body shop used to replace my trim after my Buick's complete down to the metal restoration. Only one minor problem....'they' stuck the nameplate on one fender 1" lower than on the other side. I'm the only one so far that noticed that...driving me even though one would have to circle the car very fast to notice it. It's stuck on REALLY good.
Neil
Hi, Neil. The guys at the body shop remove emblems that are stuck on with two sided tape by using fishing string. Loop both ends of the fishing string, and pull in a sawing action between the trim piece and the body. They say it doesn't hurt the paint or the part they are removing. After you get the part off you can clean the tape off.
12-03-2012, 09:08 AM
1966 24' Tradewind
Placerville
Thanks Bob. I may try that.....someday.....it is getting to be a less of an issue for me. The body shop owner, a friend and neighbor, would correct the issue. I had mentioned it to him and he looked at me with a 'Give me a break'! look. Currently he is building a second 455 that I had as an eventual replacement for my current aging engine.
Neil
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
12-04-2012, 02:37 PM
Austin
I went to WalMart and found the "3M molding tape". Now to apply it: I think I'll wait until the strips come loose again.
