Old 07-13-2018, 05:31 PM   #1
MollyMac
2017 25' Flying Cloud
Hoover , Alabama
Sulphur Gas Smell
We set up camp at a location in GA. Everything was fine, but now there is an obnoxious and thick smell of Sulphur or rotten eggs....I am assuming its the campground, the water system or the sewer...but I want to make sure it has nothing to do with the Trailer (FC 25" 2017). Anyone have a guess. All systems seem to be working fine.
Mollymac
MollyMac is offline   Reply With Quote
Old 07-13-2018, 05:33 PM   #2
2014 25' FB Flying Cloud
Grand Rapids , Michigan
Do you drain your water heater after camping/before you store the trailer? This is a pretty common issue if there is “old” water in the water heater.
MIFC is offline   Reply With Quote
Old 07-13-2018, 05:35 PM   #3
Goal15's Avatar
Holly Lake Ranch , Texas
Check your batteries to make sure they aren't boiling.
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 07-13-2018, 05:40 PM   #4
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yep, you got a battery burning up. Don’t ask me how I know
Old 07-13-2018, 05:52 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Battery is most likely bad. Do not leave it, since it can explode if it is continuously charged and internally shorted.
If it is leaking acid, remove the battery then flush the box with water then use a product to neutralize the acid.
Battery acid can be neutralized with baking soda, but it will leave a paste that will conduct electricity and will not totally wash away. So get a battery cleaning/neutralizing product to clean the cables and connectors that get acid on the surfaces.
Alan
Old 07-13-2018, 05:57 PM   #6
Santa Rosa , California
I had the egg smell a couple of weeks ago. Both batteries were bad in my 2018 Cloud. Contact your dealer and see if they're still under warranty. If so, you can get them replaced wherever that brand is sold. I applied the credit to two Fallriver DC105-12 AGM sealed batteries (it was a very tight fit so I slightly modified the battery box).
WEAR EYE PROTECTION
KEEP YOUR FIRE EXTINGUISHER HANDY (the fumes can be flammable)
--Sean
SeanWasHere is offline   Reply With Quote
Old 07-13-2018, 06:01 PM   #7
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
I agree. That smell is usually from a badly overcharged battery.
Old 07-13-2018, 06:09 PM   #8
1981 31' Excella II
New Market , Alabama
Check them and add water to them. Keep the outside door open if yours has them. Be careful not to create sparks. Batteries can and have exploded. There are other things than can smell but you need to rule this out before things go boom.
Perry
Old 07-16-2018, 10:05 AM   #9
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Mollymac
Hi Mollymac,
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at customer_support@airstream.com
Thank you.
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 07-16-2018, 11:46 AM   #10
dasams's Avatar
Marin , California
...but now there is an obnoxious and thick smell of Sulphur or rotten eggs....
You have a shorted cell. Been there done that. Pull both batteries and take them to your nearest Interstate dealer. They will check all the cells and they will replace bad batteries under warranty.
2006 Cayenne S with V8, air suspension, factory tow
2018 FC 27 FB
2017 FC 25 RB Gone
dasams is offline   Reply With Quote
Sewer Gas Smell davespann Waste Systems, Tanks & Totes 18 07-24-2016 08:57 PM
What is this obnoxious sulphur smell inside our trailer? Ntex General Repair Forum 47 09-01-2015 10:53 AM
sulphur smell pbarstow Furnaces, Heaters, Fireplaces & Air Conditioning 14 07-16-2010 08:45 PM
Low sulphur vs ultra-lo sulphur diesel? ScottW Tow Vehicles 24 02-27-2008 02:35 PM
Inspector needed Sulphur Springs, TX (near Dallas) bstjames Trailer Values 2 11-25-2007 03:25 PM
