Old 04-08-2012, 02:02 AM   #1
howco's Avatar
1970 27' Overlander
Sumner , Washington
sulfur stink
Started 'full timing' about a week ago, so been shaking small problems out of our 70 A/S....... Came home tonight with a strong sulfur, rotten egg smell. Jumped online, saw fifty blogs about hot water heater and water fungus problems, Well water smells fine. This was 'very strong smell'. Hint, back window of rear bath was open. Checked fifty things, finally checked converter, seemed ok, no over heating or smells. Finally checked the battery; it was hot. Totally out of distilled water, it had cooked out all of the 'sulfuric' acid, thus the sulfur smell. The rear window is right above the battery rear hatch, and it just filled the whole trailer with bad smells.......filled it full of distilled water, smell stopped immediately. Now to figure out why?
Have not towed it in a week or more, been on shore power, plugged in to power supply, why? Any suggestions? bad inverter??
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 04-08-2012, 03:18 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
over charged battery
With a modern converter, the batteries should not have been overcharged. The old style converters were noted for doing that. Check the charge voltage output from the converter. Replace the converter if it is too high and overcharging the batteries.
Old 04-08-2012, 04:19 AM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If your univolt is original, the 69 through 74 (or thereabouts) were notorious for failing. When this happens the voltage goes high and boils the battery.
If a voltmeter check shows voltage much above 13.8 you have a charger failure. If the voltage is ok you most likely have a shorted battery cell.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-08-2012, 05:09 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Yep...time to convert the converter. or hire a battery sitter.
Not worth taking the chance of the same happening with a new battery.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 04-08-2012, 05:10 AM   #5
seldencove's Avatar
1963 28' Ambassador
Lyme , Connecticut
Images: 16
Are you sure its the battery? Make sure its not a gas/ propane leak. Propane has an additive that smells like sulfur/ rotten eggs to alert people to a leak. As soon as you said sulfur, I thought gas leak.
2005 Ford Excursion V-10
Reese Trunnion Bar with dual cam sway control
Prodigy P3 brake control
seldencove is offline   Reply With Quote
Old 04-08-2012, 06:55 AM   #6
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
also if the propane is about to run out it will put some of that smell out there too...sometimes faint but you can smell it.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 04-08-2012, 07:17 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The smell in propane is more like a skunk smell. Sounds like the converter is your problem. Time to upgrade.
If you are parked more or less permanently you can disconnect the battery and just use the converter if it is one of the modern types. A battery switch would make this an easy step. Just remember to reconnect the battery before hitting the road.
Old 04-08-2012, 02:41 PM   #8
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I had an SOB ('76 Shasta) that used to boil out the battery when it was on shore power. Somehow I always forgot to check the battery level until it was too late.
That said, though, you will find that tyour battery will likely need replacing as well as replacing your converter/charger.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 04-11-2012, 04:28 PM   #9
2004 16' International CCD
Orem , Utah
hate to tell you this
better check for dead mice
starcraft is offline   Reply With Quote
Old 04-13-2012, 05:35 PM   #10
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Had that too - after leaving mouse bait I found the squishy dead mouse in a box of dog biscuits as I reached in to get one for my dog. uuuuggghh
VE3JDZ
AIR 12148
Stink in '74 Overlander!!!!! silverdaddy General Repair Forum 6 10-04-2009 01:47 PM
Sulfur Odor in 25' Wardrobe Closet ???? 2dabeach Waste Systems, Tanks & Totes 2 03-25-2009 09:24 AM
Help please re: ultra low sulfur diesel fuel! Wingeezer Tow Vehicles 17 02-09-2009 06:45 AM
Battery Sulfur Odor spat61 General Motorhome Topics 2 12-29-2007 05:56 PM
Rotten egg / sulfur smell niss1679 Electrical - Systems, Generators, Batteries & Solar 17 10-17-2005 06:08 PM
