Old 09-20-2015, 05:11 PM   #1
1977 31' Excella 500
Bonnyville , Alberta
Suggestions For Rear Bumper!!?
Name:	ImageUploadedByAirstream Forums1442790639.984523.jpg
Hi Guys
Any suggestions for repairing this banana wrap that connects to the bumper? This seems like a difficult part to track down. Will need to fix once bumper is straight.
Thx!
Zenstream1 is offline   Reply With Quote
Old 09-20-2015, 08:25 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy,,,
Nope, they "Pop" Rivet into place. May need to Remove some Trim... Don't forget to use proper "sealant"!!! No SILICONE!!
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-21-2015, 07:53 AM   #3
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Pull the wrap off and straighten that baby out. Should be fairly soft Aluminum and easily manipulated.
desertair27 is offline   Reply With Quote
Old 09-21-2015, 08:10 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you put things back together check the flooring just inside the back of the trailer. That is a very common place for rot because of the way the sheet metal goes in under the floor and conveys water to the bottom of the floor.
Yes that seal under the banana strip is critical to sealing when you are done.
2004 Excursion 4x4
Old 09-21-2015, 05:30 PM   #5
1961 16' Bambi
Petersburg , Alaska
I have a '48 Tradewind without any bumper and made one using aluminum "C" channel for brackets and 2" aluminum tubing (2" ID) bent to the 7' trailer radius adding a 2" stand-off (7' 4" radius overall). Two tubes which I use to store the 1-1/2" sewer and gray water line with quick disconnects.
Ranger Doug is offline   Reply With Quote
Old 09-21-2015, 06:57 PM   #6
1981 31' Excella II
New Market , Alabama
Why not GET RID OF IT. Never seen that before. Mine has a corner there. Looks like that is just a water funnel. Leaks are a problem back there as it is. That plate that holds the hinge for that lid is a problem. Water hits it and goes into the floor of the trailer.
Perry
Old 09-21-2015, 07:16 PM   #7
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by Zenstream1 View Post
Attachment 248568
Hi Guys
Thx!
go look at this post, I am pretty sure that is the one you need
http://www.airforums.com/forums/f48/...ml#post1282300
airstream part #101628
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
? about the hinged rear bumper cover Bryanhu Bumpers & Bumper Storage 4 04-21-2017 08:25 PM
rear bumper harlanghoffman@sbcgl Bumpers & Bumper Storage 4 09-17-2003 06:07 PM
Rear Bumper AccessMaster General Motorhome Topics 1 04-17-2003 06:43 PM
Where to seal rear bumper? 65trotter Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 02-17-2003 02:32 PM
Looking for advice about rear bumper Cottage Bumpers & Bumper Storage 5 02-10-2003 05:58 PM
