Old 03-28-2016, 06:42 AM   #15
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Hello!
Yes,,there are of course a German brand for RV-heating.
The main brand is "TRUMA", they make dpendable furnaces, but they require totally different "basics":
-10mm steel conected propane suply.
-total different thermostates (10 wires!)
-total different exhaust and airintake
-significant smaller diam. for airhoses and total different airoutlets
If you begin to change over to "german" appliances, it requires an enormous amount of cash to change them ALL (!), you can't just change "some", because of the dufferent pressure also (we use 50millibar, ni idea what that is in psi...)
The "power" of these TRUMA furnaces is very limited, the "very big" 4000e brings max. 3,3 kw (converted to BTU almost half if the NT30-SP.
Last but not least, a TRUMA 4000e cost 1450,00€ , without ANY hardware to install.
So, now you might understand, WHY i prefer to dtay with my SUBURBAN...!
Roquefort is offline   Reply With Quote
Old 03-28-2016, 10:06 AM   #16
1974 Argosy 20
Kooskia , Idaho
Sounds like you are between a rock and a hard place with your furnace problems. I hope you are able to get the parts you need here in the states, and have them sent to you to keep your units going. It sounds like that is still your best solution.
Oh, if we were only blessed with unlimited money.
Old 03-29-2016, 11:48 PM   #17
RGates
Randy Gates's Avatar
1968 20' Globetrotter
Thousand Oaks , California
I was surprised at the virulent response to the use of a catalytic heater. Use your common sense. I know no one who runs a heater all night. I use it in the am for about 15 minutes to take off the morning chill. I couldn't care less about what mfg codes say. I do understand their logic. Just fit the equipment to your needs. I wish mfg'rs could design a refer to work then I may have more faith. All the best.
Randy Gates is offline   Reply With Quote
Old 03-31-2016, 10:10 AM   #18
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
Please remember to install a Carbon Monoxide Detector!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
Old 04-01-2016, 01:24 PM   #19
RGates
Thumbs up Good Point!
Your so correct! I have had a carbon monoxide detector hard wired in from day one of ownership. It is something folks never talk about. This is why AIRFORUMS will never get old. Always give others options when restoring and the valuable help from those experienced, in this case life saving ideas.
See ya on the road this summer!
Old 08-23-2016, 12:27 PM   #20
1973 31' Sovereign
sunnyvale , California
Hi, I have a replacement nt30 for my 31' 73 sov. The original heater was an insert into a larger box with bottom vent. The new one is self contained and dies not have the 'bottom platform's therefore doesn't line up. Anyone build a platform? If so, what materials did you use? Assume some insulating foam board or something underneath. Lemme know what's the best option! Thanks
lesnlearned is offline   Reply With Quote
Old 08-24-2016, 08:53 PM   #21
1958 18' "Footer"
and don't forget a good fire alarm!
Name:	fire detector..jpg
Steve
Furnace Suburban NT30S blower died RuneM46 Furnaces, Heaters, Fireplaces & Air Conditioning 18 12-18-2014 04:26 PM
'79 Suburban NT-30 furnace - Repair or replace? blickcd Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-08-2012 01:33 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 07:20 AM
Going to Replace the ol Suburban Furnace jjustice Furnaces, Heaters, Fireplaces & Air Conditioning 21 11-11-2010 04:35 AM
suburban NT24SP furnace problem repair or replace modnodd Furnaces, Heaters, Fireplaces & Air Conditioning 2 12-19-2008 11:21 PM
