08-22-2019, 12:51 PM
2011 27 FB International
Spokane
Subfloor Rotted -- What now? 2011 Airstream International 27 FB
We've owned our AS for 4 months now and have been full time for a month. Three weeks ago we discovered a soft spot near a wall in the bedroom. That's week one for full timing (if you're keeping track). We pulled up the vinyl and discovered the floor was rotted and clearly had been for some time. The really bad damage is about the size of a basketball and is roughly circular. We took it to Bretz RV in Missoula and they claimed to have fixed the leak. We're hopeful of that, but I'm not holding my breath. Nothing against Bretz, they really went above and beyond for us.
Now we're at the point where we're looking into subfloor replacements/patching, and I'm at a loss. The AS dealer in Scottsdale said to take it back to the mothership and that it would cost upwards of $20k. Oasis RV in Tucson said they'd likely patch it. Not sure yet on the cost. I don't want this thing done halfway, but I also don't want to sink (no pun intended) an additional $20k into the RV + a trip to Ohio. My wife and I work and live full time in the AS. Has anyone dealt with this before? I'll share some pictures in a few. Any thoughts, words of advice, or encouragement are greatly appreciated.
-Chase
08-22-2019, 01:23 PM
2012 25' FB International
Trent Woods
, North Carolina
I cannot really help, but I was talking with some owners at our recent rally and several have had your exact issue. The floor was patched, not replaced. However, what you decide to do about the vinyl is also an issue. One person I know refused to have a vinyl patch and replaced the entire floor with an upgraded, classier look. No idea of the price, but it is not a lot of vinyl or other flooring.
Larry
08-22-2019, 02:01 PM
Walnut Creek
The Long Long Honeymoon folks had Vinnie do theirs. His shop is near Sacramento now.
I would patch. Cover the vinyl with a throw rug and enjoy your life. Reno when all good and cash/time allows.
Condolences for your issue. Leaks are the enemy of wooded structure. Pat
08-22-2019, 02:10 PM
Sag Harbor
, New York
Bummer! You need to do further exploration IMO.
Starting with the leak-fixing dealer's advice, a thorough understanding of the leak process is necessary. Was there only one leak, and where? Is there any other surface evidence of "the" leak?
Take an ice pick, or very small straight screwdriver, and see if you can stick it through the vinyl flooring and into the subfloor, in other nearby locations. Can you see the subfloor and identify its composition? If you look inside your exterior storage compartments, is there any subfloor visible, perhaps with its industry stamp identifying the thickness and composition?
Assuming you have removed the rotten parts, and can see the remaining subfloor, try sticking the ice pick/screwdriver sideways into the plies of the plywood. Does the rot continue horizontally in some of the plies?
Photos would help so other folks who know your model can offer other ideas.
If you can remove ALL the rot, patching is definitely an option with today's modern epoxies like the WEST boat-building system IMO.
Good luck,
Peter
PS -- Welcome to the forum! Sorry for your baptism by fire.
PS2 -- Good advice from Pat:
08-22-2019, 02:11 PM
Vintage Kin
Fort Worth
Agreed. A patch is fine. And when you get around to it, is when you get around to it.
May as well start reading up on sealing exterior. Rivers, seams, etc. Become conversant.
08-22-2019, 02:33 PM
I'm In
, Kentucky
I was at JC mothership in 2014, having a soft spot repaired. I had taken out the furniture in that end (front) to save a few dollars. I asked about replacement and our tech said the only way they do it is to remove all the furniture, lay down a new floor and put everything back. At $130 an hour I can see where that would be expensive.
Our linoleum wasn't too bad and the tech was able to clean it up very well. You can hardly see the stained area. I'm hoping they can do the same with the other end since we have a couple of soft spots back there.
If it were me, I would just patch, especially if I was going to keep the AS for a long time. With my luck, after spending a lot of money to replace it, I'd have another leak to contend with down the road. Just patch it, enjoy it.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
08-22-2019, 03:26 PM
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Agree with patchers.
Eventually, 10 year or more mark, you will want to renovate, redecorate, redo some of the interior. At THAT point, do a frame off and use coosa board, your great grandkids will appreciate it.
08-22-2019, 03:46 PM
2009 25' FB Classic
Scottsdale
I would let RV Renovator of Mesa AZ take a look at it. They remodeled our AS Classic and we are very happy with the workmanship, price, time it took, and we went to the trailer each week to watch the work. Call Jim and speak with him they are great
Bob & Julie # 5587, 4CU in AZ
08-22-2019, 03:48 PM
Overland Adventurer
2009 34' Panamerica
Telluride
From personal experience, I would stay clear of Oasis, in tucson! Terrible!
08-22-2019, 03:54 PM
2009 25' FB Classic
Scottsdale
This was our flooring [ATTACH][ATTACH]. After AS flooring cover removed, then new flooring installed (which is water proof).
08-22-2019, 04:47 PM
Spokane
Thanks for the replies all. I'm attaching some images of the damage.
08-22-2019, 04:52 PM
Spokane
Good luck,
Peter
Bretz found multiple areas on that side that needed to be resealed. They started at the bottom and worked their way up, sealing and testing as they went.
I don't know about the type/make of the subfloor tho. I've been stabbing the hell out of the floor ever since we found the soft spot and it's driving my wife crazy--hopefully she doesn't turn the pick on me...hahaha.
We wanted to replace the flooring anyhow, so I guess we have our excuse (patch pending).
08-22-2019, 06:05 PM
2008 27' International FB
Petaluma
Hi Coltnkat!,
Redirecting you a big thread in the forums ab out this with several people reporting in. Dropping you on the page where I tell my tale of woe for my 2008 FB. My wood was intact enough to use Cold Epoxy. So far, so good! Good luck! http://www.airforums.com/forums/f396...-56099-18.html
08-22-2019, 06:08 PM
Sag Harbor
, New York
Thanks, Chase, for the photos and details. In the immediate area, I would remove that bedside cabinet, all the trim at the wall/floor junction, and the flooring ASAP. You need to get a sense of how far the moisture got [all the dark staining]. If the subfloor can bear the weight of you standing on one foot, over the worst spot, then the damage may be limited to the top plies in the plywood [which is what it appears to be IMO]. Be careful with this weight test, however, you don't want to punch through the subfloor just yet.
Looks like you have a Queen bed in the front? Next . . . you could remove the mattress, unscrew the ply top of the bed platform, and lift that platform up as a unit, placing it on a saw horse at each corner. If I have guessed right on your layout, this will let you work under the bed and remove all the flooring including trim strips at the walls.
In my opinion, you need to expose as much subfloor as you can, in order to assess where this pony wants to run. If the dark staining, and any punky/rot spots go under the wall framing, this will open up a new can of worms. Good to know this ASAP.
Each day you can put the bed platform back on the floor, and sleep on it, if your full-timing requires that.
Possible saw horses which fold up and carry good weight IMO:
https://www.amazon.com/AmazonBasics-...NsaWNrPXRydWU=
Guess I will stop here . . . lots of possible directions in which this pony can roam . . . not sure whether any of the above is possible just now for you.
You definitely need to take up some more flooring IMO . . . maybe wait on raising the bed for now? I guess the basic point is that you have the power to do more research, which will serve your decision-making well.
Good luck,
Peter
PS -- You do not need to Quote this post to maintain continuity . . . just put my name at the top.
08-22-2019, 06:54 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Rip up the vinyl. Let floor dry. Use fans. It will not dry without a fan or better, a heater. Patch rotten area. Put in an engineered floor from home depot. For me it was do it yourself. But I was living in my house and working in driveway with garage to store stuff. Getting it exposed, dried and evaluated for damage you can and need to do, it always looks worse when wet and smaller in area when dry.
08-22-2019, 08:05 PM
1989 32' Excella
Sharon Springs
, New York
We found an 18" x 20" rotted spot under our fridge. The fridge had been replaced by the PO 10 years prior and the condensation tube had not been affixed properly to drain outside of the trailer. The OSB subfloor (1989 vintage), though not wet when we found it, crumbled away. I cut away to solid subfloor, framed it out with 1/8" x 2-1/2" flat steel (bolted to the outfitters and subfloor, painted the metal with POR 15 and dropped a patch piece onto (glue/screwed) the new framing. Took a few days on/off, but it worked. Also replaced the carpet with click type flooring from Lowe's and it has travelled fine for the last 4 years. Overall cost about $300, much cheaper than whole floor shell off replacement!! Good luck and safe travels,
Jim & Gretchen
08-23-2019, 07:33 AM
2007 25' Safari
Rogers
, AR
We bought our 2008 knowing the floor under the rear dinette was probably no longer present. We took it straight to the Airstream specialists at Hoss's RV in Avoca, AR. A couple weeks and $1500 later they had the floor patched and the leak repaired.
2007 Airstream 25FB Safari LS - GY Endurance Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison
2008 Porsche Cayenne Turbo 500hp/516lb-ft
2014 Porsche Cayenne Turbo S 550hp/553tq
2005 GMC Sierra Crew Cab 5.3L built 4L60e, 40k Tru-cool
08-23-2019, 09:22 AM
2006 19' Safari SE
Tucson
No disrepect, but I have to disagree. We have been going to Oasis in Tucson with our Bambi for years and we are very pleased with their work ... everything from regular service to major skin repairs. This is the first time I have heard of anyone not being happy with them. I don't have any experience with their floor repair work, but a blanket "terrible" is not fair.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
08-23-2019, 09:51 AM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
Can someone please remind me why Airstream still does not install composite floors (like the did in some of the Argosy line) or at the VERY least use marine grade plywood that would last longer than 5-10 years....oh yea and properly caulk and seal the RV would be helpful too. Just too many darn stories about rotted floors and leaks on relatively newer Airstreams that initially cost nearly 6 figures......it's unconscionable.
I know years ago they would put a coating around the outer edge of the subfloor, but IMHO, that is just a token gesture.
08-23-2019, 10:07 AM
Walnut Creek
Originally Posted by panamerican
Can someone please remind me why Airstream still does not install composite floors -- snip -- properly caulk and seal the RV -- snip --
The floor material is a cost issue - it works if kept dry. The leak thing is maintenance. The coach is tested in a water booth at the factory and any leaks identified are fixed.
It is up to the owner to either use their warranty to correct the leaks that sneak through and maintain the seals after the warranty has expired.
Now we all buy this coach. It's up to us to keep the coach dry. If you can't sign up for that, don't buy an Airstream or do a full Reno and replace the floor when you buy it. It's our money and our choice. No one makes anyoney buy an Airstream.
Now, tell all the newbies and suggest a visit to the sealant thread as well. Pat
