Old 04-09-2016, 04:49 PM   #1
BradT
2007 27' Safari FB SE
Milton , Georgia
Stripped stabilizer bolt
When inspecting my 2007 Safari 27 FB I found the right rear stabilizer was loose. The stabilizer is normally fastened with 2 bolts near the curb and one bolt toward the center-line of the trailer. I found the single bolt toward the center-line was missing, and the stabilizer was hanging down about 1/2 an inch where the bolt was missing.
I found that the hole where the bolt goes is completely stripped out. A correct sized replacement bolt will not engage at all. The underbelly skin prevents any access to add a nut and washer so the bolt could tightened up.
Does anybody have experience with a repair that doesn't involve cutting an access opening in the underbelly skin? Perhaps drilling and tapping for a larger sized bolt might work, but I do not know what the structure looks like to determine if there is enough metal to support a larger bolt.
Thanks!
Name:	2016-4-9 AS Stabilizer bolt.jpg
bradt is offline   Reply With Quote
Old 04-09-2016, 05:11 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Surprising that yours look as rusty as mine!
I live in Canada where a lot of road salt is used and figured that was the cause in my case!
Just two weeks ago in Asheville NC I had one of the rusty brace bolts bust off when I canked the stablizer down with a drill. Luckily that was an easy fix and I went around all of them with some WD-40 release spray to try and avoid repeats!
In your case, I would be inclined to have a try with the appropriate drill and tap for the next size up - not much to lose!
If that didn't work, what about cutting out the belly pan in that area and then you could fix thngs one way or another if only maybe with a nut and bolt I would think.
You could then just pop rivet a patch plate over the access area you had created. I think that would be my approach
But maybe others will have smarter ideas! I doubt you are the first with this problem to solve! One of the great things about this forum!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 04-10-2016, 11:58 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Either drill and tap or use a 1/4 x 20 Riv-nut
Old 04-11-2016, 12:20 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my stabilizers did that several years ago. I drilled 1" holes in the belly pan near the stripped holes. I installed nuts and bolts instead of the self tappers. The 1" hole leaves just enough room to slide the boxed end of a wrench in the hole with a nut held in place with putty or tape. This will hold the nut in place until you get it all tight. Mine never came loose again. I covered the holes with small pieces of duct tape.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-18-2016, 04:02 PM   #5
BradT
Milton , Georgia
Thanks for the ideas!
Thank you for your ideas to repair the stabilizer bolt. I decided to go ahead and cut a hole with a 1-3/8 hole saw next to the bolt location. I drilled out the stabilizer hole to 3/8" and inserted a bolt with washer and locking nut on the inside. Taped the nut onto my box end wrench, inserted it thru the access hole, and it worked great. Tightened up and will be very secure.
To cover the hole, I put silicone around the hole, a little patch of aluminum, and pop rivets.
First time to cut into the belly pan. Probably not the last!
Thanks again for your ideas.
Name:	2016-4-18 Stabilizer bolt repair.jpg
Old 04-24-2016, 05:24 PM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
bradt - silicone is acid-based, and will damage the aluminum. The sealant of choice is Vulkem (Acryl-R).
See http://www.airforums.com/forums/f456...ry-116214.html
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 04-24-2016, 05:27 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The new approved sealant for Airstreams is Adseal, which is silicone.
https://store.airstream.com/product/...m-sealant-kit/
Old 04-24-2016, 10:04 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I am using Adseal now... Where I have used it, there have only been a few separations... Most likely due to poor prep "my fault most likely"...
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-25-2016, 06:31 AM   #9
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I thought that silicone base and was a NO NO around aluminum ???? Has something been done to make it appropriate for our usage ??
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Leveling Jack End Bolt Stripped tarh2o Jacks, Stabilizers, Lifting and Leveling 10 12-04-2013 05:26 AM
BAL stabilizer bracket bolt stripped SeymourAC Jacks, Stabilizers, Lifting and Leveling 12 06-24-2013 06:39 AM
Stripped lug bolt holes chris's 67 Wheels, Hubs & Bearings 3 03-30-2008 05:27 PM
can a 92 limited classic be stripped and polished? 0557 Cleaning, Stripping & Polishing 6 02-23-2004 09:14 AM
