Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Prev Previous Post   Next Post Next
Old 06-22-2002, 12:04 PM   #1
Profile:
Question Strange noise?? Univolt?? Brakes??
Just bought a '76 Excella 500, central bathroom. When plugged in the 120 V hear a noise behind the oven that sounds like a motor running. Its not the water pump that can be turned on/off on the panel above the range. Any ideas?
About the Univolt... do I understand correctly the the 120 V circuits, lighting, etc., will operate off of the 12 V battery?
Brakes... the brakes on the wheels are hydraulic, yet the trailering electrical connector has a terminal for brake? I'm confused. Also there is some sort of "plunger switch" extending from the front, sort of behind the propane tanks, that is labelled about pushing to release the brakes. More confusion!
Any and all help and enlightenment will be greatly appreciated. Thanks
rroessler is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 07:23 AM
