Old 10-12-2014, 12:04 PM   #1
Storing parts outside under cover?
We bought a 66 Ambassador International last June. I'm planning a full shell off rehab. The interior is in pretty good shape so I hope to reuse what I can.
So my question is - we have a large covered storage "shed" with open sides. I could easily store "parts" in there. It's definitely dry but since the sides are open its exposed to the outside temperature and humidity. Since we live near Portland, it's going to be raining for the next 6+ months...
Any thoughts on the practicality of this? An alternative would be to dramatically clean out my shop to make room for the parts (easy to say, hard to do).
Rasjad
rasjad is offline   Reply With Quote
Old 10-12-2014, 12:44 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Don't put things directly on the ground. The sun pulls moisture up all the time.I would consider building a platform of pallets, covering that with plastic, placing the parts on it and folding the sides of the plastic up leaving an opening at the top and under the shed roof. That should keep things dry and allow it to breath.
2004 Excursion 4x4
Old 10-12-2014, 12:45 PM   #3
Rasjad
Out of the weather is always superior.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-12-2014, 05:16 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I live in the humid and wet deep south. My AS parts are stored on pallets under a 3 sided shed. No problems. Around here if you sit around long enough in the wrong place stuff will grow on YOU!
Aaron
WBCCI #XXXX AIR #2495
Storing outside Question rodsterinfl Winterizing, Storage, Carports & Covers 6 02-18-2012 05:00 AM
Storing my AS outside in Minnesota winter? bertheep Winterizing, Storage, Carports & Covers 11 09-03-2011 04:13 PM
Little cover outside of door? toastercoaster54 Lights - Interior & Exterior 17 10-23-2007 06:56 AM
Question about storing outside? tiniree Winterizing, Storage, Carports & Covers 5 04-23-2003 01:57 PM
