Old 06-07-2019, 03:17 AM   #1
2016 25' Flying Cloud
Williamsburg , Virginia
Storage Compartment Lock Replacement
Any advice on replacing the locking mechanism on the storage compartment on a newer airstream? This is the mechanism that has a key lock at the bottom and a lift handle that rotates 90 degrees. I have the new one in hand but with zero instructions.
Ttaylor is offline   Reply With Quote
Old 06-09-2019, 10:52 AM   #2
Replaced the lock mechanism yesterday, very easy. Drilled out the lock, opened the storage door. There is a small bolt that holds the mechanism in place. Installed the new one with new gasket, had to use old cam lever but put it on the new unit as it came off the old. No problem at all.
Old 06-09-2019, 11:00 AM   #3
2007 22' International CCD
Pictures for future reference, please?
Storage compartment lock mfg 28totow Doors & Locks 1 10-23-2017 06:08 PM
Storage compartment lock for 1996 34' Excella Larry C General Repair Forum 2 03-27-2017 04:08 PM
Storage compartment lock replacement jmichaelr Exterior Storage Compartments & Access Doors 3 11-16-2016 10:33 AM
Rear Storage Compartment Does Not Lock? Whirlaway 2007 Safari SE 4 03-27-2007 04:05 AM
rear door storage compartment lock and latch maxandgeorgia Bumpers & Bumper Storage 4 08-06-2006 09:00 AM
