Old 09-17-2019, 06:28 PM   #1
broupman's Avatar
2015 25' FB Flying Cloud
Salt Lake City , Utah
Step by step Dometic 7 cu ft. refrigerator removal
I wanted to make my refrigerator more efficient by installing fans behind it, but could not find a good step by step process to remove the fridge. So I made notes and took some pictures.
  • Remove Phillips screws on hinge supports located on each side of the top edge of fridge.
  • Top display/control panel can then be removed by pulling straight out.
  • Unplug both plugs from the display and control panel, freeing the display/control panel from fridge.
ID:	352392   Click image for larger version
broupman is offline   Reply With Quote
Old 09-17-2019, 06:30 PM   #2
broupman's Avatar
  • Top pin/screw of freezer door is removed with 10mm wrenches.
  • Unscrew by turning the top of the 10mm pin/screw, while holding the lock nut below with 10mm wrench.
  • Washer goes between top pin/screw and lock nut.
Old 09-17-2019, 06:32 PM   #3
broupman's Avatar
  • When top pin/screw and lock nut have been removed, freezer door can be removed.
  • Remove freezer door by lifting straight up and setting aside.
  • Lower freezer door pin/screw is also the upper fridge door pin/screw.
Old 09-17-2019, 06:33 PM   #4
broupman's Avatar
  • Use two 10mm wrenches to remove lower freezer door/ upper fridge door pin/screw.
Old 09-17-2019, 06:35 PM   #5
broupman's Avatar
  • Remove fridge door by lifting straight up and setting aside.
Old 09-17-2019, 06:36 PM   #6
broupman's Avatar
  • With freezer and fridge doors removed, start removing the two screws located along the top edge of the fridge frame.
Old 09-17-2019, 06:37 PM   #7
broupman's Avatar
  • Check for additional screws along the frame edge of fridge.
  • There should be only one on the latch side of the fridge, located towards the top.
Old 09-17-2019, 06:38 PM   #8
broupman's Avatar
  • Remove two screws from the bottom edge of fridge.
  • Bottom trim can now be removed and set aside.
  • This will expose a bead of caulk between the fridge and cabinet.
  • Use a putty knife to cut through the caulk.
Old 09-17-2019, 06:40 PM   #9
broupman's Avatar
  • Everything holding in the fridge from inside the trailer should now be free.
  • Start at the back of the fridge from the access vent on the outside of the trailer.
  • Remove the propane line, and cap both ends to keep dust and debris out.
Old 09-17-2019, 06:41 PM   #10
broupman's Avatar
  • Remove the 12v DC wires from the power termination block.
Old 09-17-2019, 06:43 PM   #11
broupman's Avatar
  • There are two securing points located at the back of the fridge and are 10mm anchor bolts.
  • Remove second anchor bold and slide condensation drain tube from clamp.
ID:	352403   Click image for larger version
Old 09-17-2019, 06:45 PM   #12
broupman's Avatar
  • Remove 110AC plug.
  • The fridge should now be free to slide out from the inside of the trailer.
  • The fridge is not heavy, have a box/crate ready to slide fridge out of cabinet compartment.
ID:	352405   Click image for larger version
Old 09-18-2019, 11:35 AM   #13
1993 25' Excella
Scenic , Arizona
Fridge
Thanks for the blow by blow description, very informative.
Hope I never need it.
dieppe9 is offline   Reply With Quote
Old 09-18-2019, 03:31 PM   #14
Life is a Highway's Avatar
2019 25' Flying Cloud
Lady Lake , Florida
Removal of Fridge
Thank you for taking the time to show the steps.
We will be watching this tomorrow as our new Refrigerator in a new 2019 is being replaced. I am having extra fans installed while it is out.
Life is a Highway is offline   Reply With Quote
Old 09-18-2019, 05:39 PM   #15
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Broupman, thanks for the detailed instructions and photos! Do you have any of the fans you installed? Id be interested in seeing how / what you did there. Weve got a 3-way in our Globetrotter and think it could use some more ventilation.
2019 27 Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 09-18-2019, 10:33 PM   #16
broupman's Avatar
I also have step by step notes/pictures on the fan installs. To answer your question, this is where I put the fans pushing the air upwards. It's surprising how much of a difference the fans make towards the fridge's efficiency. For temperatures under 90, the factory design seemed to work fine. At 90 or above, I noticed my fridge struggling. With the fans installed, I don't notice it struggling at all anymore. The "start-up" time for the fridge to get down to temperature is noticeably faster as well. So I'd say it's not just a hot weather enhancement.
The picture is looking up with the fridge removed.
Here's the link to a good kit.
https://www.ebay.com/itm/2-DOMETIC-R....c100290.m3507
Old 09-21-2019, 09:08 AM   #17
Journeyman
2016 25' International
Deerfield , Massachusetts
Hey gang,
Here's a video showing the same process, end to end--except I did not remove the doors or any hinge screws...
https://youtu.be/WQDBur7ItHo
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 09-21-2019, 09:31 AM   #18
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
Thank you! I have a project that may involve pulling the fridge out temporarily and this is invaluable! Your timing is perfect!
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-21-2019, 11:36 AM   #19
Journeyman
Once you know how to do it, it's a remarkably simple process requiring only a couple tools. Go for it!
Old 09-25-2019, 02:54 PM   #20
broupman's Avatar
Something to be mindful of, if keeping the doors on when removing the fridge..... The stainless dents very easily, and when wrestling the fridge out they swing open very easily. I think you get my point. Taping them so they wont swing open, even though they latch is good insurance. If you plan on leaving them on the fridge.
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 795 07-22-2018 11:28 AM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 04:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 10:47 PM
Step-by-step sewing an awning yukionna Awnings 11 12-28-2006 02:37 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
