Old 02-15-2013, 12:18 PM   #1
2005 34' Classic
Kitchener , Ontario
Stainless steel upgrade parts
I want to replace the rusted water compartment in my '98 30' Excella 1000 with a stainless steel model. The Airstream store is 'out of stock' on these. Does anyone know of an alternate supplier?
jonaz is offline   Reply With Quote
Old 03-20-2013, 10:48 PM   #2
2003 30' Classic S/O
Salisbury , North Carolina
Same Problem
I have the same issue; steel utility box paint is gone and box is rusting. I didn't know Airstream had the part. So my plan was to remove the box and either remove the rust and re-paint or make a box from plastic or sheet aluminum. But would rather not. Please let me know if you find an alternate source. Thanks.
AirRoamer is offline   Reply With Quote
Old 03-21-2013, 06:17 AM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
These SS parts originated at Roger Williams AS DFW Tx. No longer available.
AFAIK...the JC store is the sole source now.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-21-2013, 06:22 AM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Roger Williams still had the SS exhaust vent unless I bought the last one a few weeks ago.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 03-21-2013, 07:50 AM   #5
2008 16' Safari
Destrehan , Louisiana
You have to be careful with stainless steel parts on an aluminum trailer. Metal to metal contact will set up galvanic transfer. The aluminum becomes the sacrifical metal and just turns to powder. Stay will plastic or aluminum parts if posible.
dlb435 is offline   Reply With Quote
Old 03-21-2013, 08:02 AM   #6
Thumbs up
Replaced all exterior fasteners along with the stainless door up-grades with no galvanic problems.
I believe they are close enough on the chart not to cause any problems. http://www.npfasteners.com/pdfs/galv...sion-chart.pdf
Plus Airstreams are or shouldn't be immersed.
PFC
"Tahawus"
RLC
John Prine
Old 04-17-2013, 03:07 PM   #7
2005 34' Classic
Kitchener , Ontario
Update!
Airstream had the SS compartment back in stock in late March and I was able to get it from them. Looks good - can't wait for our park to open and spring to arrive so I can install it. (That should be interesting, but our dealer, Can-Am in London, ON, Canada is always an excellent resource if I need help.)
Thanks for the replies.
Old 04-18-2013, 01:43 AM   #8
mutcth's Avatar
2007 23' Safari SE
Central , Connecticut
Jim, I also bought one this winter from them. Did you install yours yet? Mine is installed and looks great, but I'm less than thrilled about the louvers clanking every time I close the door - curious if anyone has a fix to this.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
mutcth is offline   Reply With Quote
Old 04-18-2013, 04:20 AM   #9
Thumbs up
This works best for us...helps flow when fan is on also, and yes I have forgotten to remove before getting on the road.
PFC
"Tahawus"
RLC
John Prine
Old 04-18-2013, 05:45 AM   #10
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A thin layer of rubber as a gasket between the steel and aluminum should do the trick, if you have to put a stainless fitting on an aluminum trailer. Cork also works as a gasket material. So does sheet plastic such as visqueen. Even roofing felt will work.
Your fasteners should receive a thorough coating of dielectric grease before you screw them in, to maximize your protection against galvanic corrosion.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-18-2013, 06:08 AM   #11
Thumbs up
Good point's Pro...
I split a 1/4" ID section of clear plastic tubing as a seal against the AS.
PFC
"Tahawus"
RLC
John Prine
Old 04-21-2013, 06:29 PM   #12
interstateflyer's Avatar
2017 25' International
Los Osos , California
I purchased a SS Fan Vent at my AS dealer yesterday. Un-wraped it today and was surprised to find a very warped flap. Also the little securing tab on the left is quite difficult to move.
Does any of this sound familiar. Can I expect better from an exchange?
Also, the SS heater door that I bought is without a securing tab for the vent (like the one on the original Atwood door). So the vent wanted to fall back into the compartment. Nothing that a bit of foil heat duct tape couldn't fix. The door also seems to be warped. Could be that a brazed-on hinge tube is slightly off.
Bottom line......not terribly impressed so far by the pricey SS upgrades.
Name:	SS Fan Vent-Warped.jpg
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 04-21-2013, 08:45 PM   #13
I can't comment...got our's from Roger Williams. None of the SS vents have the lock tab, my clothespin can also hold it closed on a windy day.
If the dealer won't help, call AS & send a pic.
PFC
"Tahawus"
RLC
John Prine
Old 04-22-2013, 12:11 AM   #14
Sounds like I got an odd one. Will return to my AS dealer.
