Old 06-08-2014, 01:05 PM   #1
Registered User
2011 23' Flying Cloud
Sparta , New Jersey
Question Stabilizer (sway bar) - SOS from the road
Hi Air Streamers,
Hoping someone can give me some
advice on how to get my sway bar
to sit in the saddle properly. It was
fine before we left, but I'm thinking
A hard turn out of a gas station might
Have misaligned the saddle somehow.
we've taken the bars out to park the
trailer in its camping spot and now we
can't set the bar in properly, so the
straight end of it sits on the saddle
And the curved end overshoots it.
We are going to be driving for the next
8 days on the highway and going through
some windy terrain so I wanted to
keep them, but in this situation am
I better off without them? I saw the
AS dealer whack a saddle into place with
a hammer once but don't want to make
things worse. Thanks ahead of time
for any tips. At a rest stop in Ohio
headed to Indiana, seems ok so far.
meg2ak is offline   Reply With Quote
Old 06-08-2014, 01:38 PM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'm assuming you have a Reese Dual Cam unit. In my experience with that hitch, the snap up bracket that the chain hooks on can become loose and slide which will cause it to be in the wrong location on the trailer A frame. Normally its just a matter of loosening the bolts that hold it and sliding it back into position. You can normally see the marks on the A frame where the bolts were tightened originally and scratched the paint on the A frame. You can always measure the difference on the side that fits correctly, from the nose of the trailer to the bracket, and on the side if not correct, use that same measurement to align the snap up bracket.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-08-2014, 01:51 PM   #3
SteveH's Avatar
Common Sense , Texas
Originally Posted by meg2ak View Post
Hi Air Streamers,
You don't really give us enough information like type of hitch, type of sway bar, etc.
However, from what you have written, like Jack, I think you have a late model Reese Dual Cam, and if you do, it sounds like the cam is not in the correct place on the weight distribution bar.
If the above is true, you may have a bent cam rod, which will happen if the hitch is not set up correctly, and you make a tight turn. Again, if all of this is true, the cam rod will have to be replaced, but until that can happen, I would advise you to proceed as you are with caution.
All of this is too many "ifs" for my comfort, so a picture of the problem area would really help us to help you.
Regards,
Steve
Old 06-08-2014, 01:55 PM   #4
SteveH's Avatar
OK, I have searched your posts, and found a picture of your rig that shows that you indeed do have a Reese Dual Cam hitch, new version.
I think what I posted above should be accurate.
Regards,
Steve
Stabilizer/Sway Bar for New Camper Bettye Hitches, Couplers & Balls 6 07-30-2012 02:34 PM
Rear Stabilizer Bar jbwsc Land Yacht/Legacy Motorhomes 5 09-20-2006 06:00 PM
Torsion Bar vs Sway Bar acrane Hitches, Couplers & Balls 9 07-31-2006 06:11 AM
Rear Stabilizer Bar P-30 Stantank Mechanics Corner - Engines, Transmission & More... 16 01-07-2006 10:25 AM
SOS ** Moraine Rally ** SOS flamingo-kid1 The Rally Zone 7 06-13-2004 09:44 PM
