Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 11-01-2013, 07:37 PM   #1
2013 25' Flying Cloud
Wethersfield , Connecticut
Stabilizer jacks down while I hitched up
So today I raised up the hitch to hitch up and them realized the stabilizers were still down! I lowered it again right away but now the stabilizer rod that I turn to raise and lower the bars is closer to the bottom of the airstream than it was previously. This is the same on both the rear ones. It is not touching and turns fine but did I bend something such as the frame by doing this? I feel like an fool that I forgot to raise them!
Thanks!
Thomas_G is offline   Reply With Quote
Old 11-01-2013, 08:02 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You aren't the first and won't be the last.
I would check the mounting bolts to make sure they are secure.
Chances are you twisted the outboard portion up and above the inside mounting point. As long as you have not wrinkled the shell. I would not be too concerned.
Think of it this way. You don't have to bend over as far now to crank them down.
Old 11-01-2013, 08:12 PM   #3
Originally Posted by TG Twinkie View Post
You aren't the first and won't be the last. I would check the mounting bolts to make sure they are secure. Chances are you twisted the outboard portion up and above the inside mounting point. As long as you have not wrinkled the shell. I would not be too concerned. Think of it this way. You don't have to bend over as far now to crank them down.
Thank you so much.
I am taking it to the dealer for a few warranty items in a few days. If I mention this do you think they can rotate them back or should I just let it go and move on?
The outer shell seems fine though.
Old 11-01-2013, 09:02 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Just be careful they don't charge you for something you don't need.
Old 11-04-2013, 09:03 AM   #5
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
I did the same thing. Crawled under there, took them off. Went back into my shop, put them in a vise, and bent them back into perfect shape. Lubricated them, and reinstalled. Not hard. Made me feel better.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
Silver Otter is offline   Reply With Quote
Old 11-19-2013, 09:10 AM   #6
rogerdodger's Avatar
1974 Argosy 28
Fresno/Clovis , California
I replaced a stabilizer the PO left down and bent so badly it no longer touched ground when lowered. Cost $85 + shipping. So $85 X 2 = $170 lesson learned.
Roger
rogerdodger is offline   Reply With Quote
Old 11-19-2013, 09:28 AM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Do what Silver Otter did - or go on the internet and buy new for less money than the dealer would charge. On a 1 to 10 scale of difficulty changing them is probably less than a 1.
Paula
Old 11-19-2013, 09:52 AM   #8
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
The one thing I would check is the fit of the door, both alignment and gap all around. I may or may not have done the same thing and it seemed that the gap at the bottom of the door (on the edge where it meets the trailer body away from the hinge) was larger than the gap at the top. It's possible for a dealer to re-torque the door but I had mine done when in was at the Mothership for maintenance.
Good luck!
John S.
JDS is offline   Reply With Quote
'76 Argosy Steering Stabilizer - help MrJ Mechanics Corner - Engines, Transmission & More... 9 05-08-2012 09:57 AM
BAL jacks mnboy1960 Jacks, Stabilizers, Lifting and Leveling 21 09-13-2011 05:25 PM
LSE 19' Stabilizer Wanted zagarino Jacks, Stabilizers, Lifting and Leveling 0 06-22-2011 02:00 AM
'78 Argosy Minuet broken rear stabilizer jack ArgosyMinuet All Argosy Trailers 2 06-20-2011 08:42 AM
