Old 12-01-2012, 12:34 PM   #1
jornvango's Avatar
Squeaky towing sounds
While driving home from New Mexico, it seems that the squeaky noises from the towing hook have increased. Especially while driving slowly.
Is there anything I can try to minimize the squeaks?
jornvango is offline   Reply With Quote
Old 12-01-2012, 12:48 PM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
It probably a hitchhiking prairie dog.
Have you tried a little lubrication on the ball, coupler and other parts subject to friction?
Of course the gopher may initially squeek more.
Old 12-01-2012, 01:12 PM   #3
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
I hope that the ball is lubricated on your tow hitch and everything that has a bolt and not is still tight. If it is then I'd be looking for something rubbing that should not be, or a bearing going bad somewhere on one of the trailer wheels.
arcamedies is offline   Reply With Quote
Old 12-01-2012, 01:18 PM   #4
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
What kind of hitch do you have?
MaxTow is offline   Reply With Quote
Old 12-01-2012, 01:33 PM   #5
jornvango's Avatar
This is our hitch. I haven't lubricated anything in this area since we bought it two months ago (and used every weekend since then).
I suspect the sound comes from this area and not the wheels.
Can I simply spray lubricant on the ball and inside the coupler?
Both look very dry.
Old 12-01-2012, 01:34 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Does it squeak in turns or straight ahead, or both?
Do you use the friction sway bar attachment?
doug k
Old 12-01-2012, 01:36 PM   #7
jornvango's Avatar
We notice it when driving slowly and more squeaky while turning or driving on a dirt road.
Old 12-01-2012, 01:48 PM   #8
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
You will want to lubricate the ball as well as where the spring bars meet with the hitch. The spring bars need to rotate when you turn the rig. As there a significant amount of force being applied in the area, lubrication is required so that it reduced wear (and squeak).
Do you have an owners manual for the hitch? If not, you can likely get one on line from the manufacturer. Have a look through for maintenance requirements.
Old 12-01-2012, 02:03 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Attachment 173681
Axle grease on the ball.....you did do that, huh? NO lubricant on the sway bar. If that's what's squeeking....that's GOGD.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-01-2012, 02:09 PM   #10
MaxTow's Avatar
2005 30' Safari
Kanata , Ontario
Neil
Check the manual for your hitch. The Equal-i-zer hitch that we had on our SOB suggested lubrication on the spring bars (that were also the sway bars)
Old 12-01-2012, 04:19 PM   #11
jornvango's Avatar
According to the AS manual, we need to apply hitch ball lube or wheel bearing grease on the hitch and leveling bars.
I guess I can find that at Autozone.
Old 12-01-2012, 05:05 PM   #12
2012 25' FB Flying Cloud
Grand Rapids , Michigan
I have a Reese hitch. It suggests Vaseline on the ball and a couple drops of utility oil where the bars insert into the hitch. There is a small hole above each arm socket to apply the oil.
Jwestman is offline   Reply With Quote
Old 12-02-2012, 04:56 AM   #13
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Squeaks?....how 'bout breakaway switch?
Old 12-02-2012, 09:09 AM   #14
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
Both look very dry.
Attachment 173681
You should lube the ball and the head where the sway bars go into by the ball so they can pivot. Reese has oil holes on the top so you can drop some in but simply wiping the sway bars works just as well to lube the pivots.
The nuts look ok but be sure they are tight. Don't belive I've seen so much wiring coiled on a trailer tongue, you may want that looked at as well to clean that up.
