Old 02-07-2010, 01:35 PM   #1
Spokane , Washington
Question Sport 22 dinette problems
I've just purchased a 2010 22 Sport with a pedestal dinette mounted on a lift system. The table rotates and slides, but it appears that the table is mounted incorrectly. When the table is in the narrow position, aligned with the edge of the outer seats, the table is too close to use by anyone seated on the back cushion of the u-shaped dinette. The sliding mechanism slides back towards the cushion, making the space even smaller. When I tried rotating the table top 180 degrees, this alleviates the space problem with the back seating area, but the table then slides in the other direction, toward the counter top.
Another problem is when I tried to lower the table to convert to a bed, the rubber feet on the bottom of the table don't line up correctly, so the table doesn't seat properly. The rubber feet are designed to fit inside the seat well to keep the table from turning, but one side ends up on top of the bench. This creates a big hump where the table is positioned.
Any ideas on how I can detach the table and reverse the slide?
Gary P is offline   Reply With Quote
Old 02-09-2010, 02:29 PM   #2
Louie
2008 27' Classic FB
Hope Valley , Rhode Island
Send a message via Yahoo to bizetwo
It sounds like another opps in the quality control. Better take it to the dealer let them fix it. This way it is documented in case something else isn't just right. Trust me you'll find more as time passes.
Louis
bizetwo is offline   Reply With Quote
Old 02-09-2010, 05:05 PM   #3
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Can you post a picture of this issue. It sounds interesting.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 02-23-2010, 07:38 AM   #4
Colonial Airstream NJ
Colonial Airstream's Avatar
1968 17' Caravel
Lakewood , New Jersey
Images: 79
I had the same problem on a unit that just came in. We took the sliding track off and repositioned it in the center of the table. Now the unit will slides out so there is more room in the dinette and slides in to make the aisle easier to pass.
I am writing this to Airstream to make sure future units are corrected.
Photos of the Dinette
Colonial Airstream NJ - 2010 Airstream Sport 22' FB
Patrick Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-9019 www.colonialairstream.com
Colonial Airstream is offline   Reply With Quote
Old 04-01-2013, 10:22 PM   #5
Bend , Oregon
Need a tutorial on the my 22 Sport dinette table
Just spent my first weekend in my new 2013 Sport 22. Had a great time but couldn't figure out the dinette. Have the same issues as the original post by Gary P in 2010. Is this an improperly mounted table? What configuration is best for sleeping so that the table to "flush" with the seats? Can any Sport 22 owners offer help?
chaeha is offline   Reply With Quote
Old 04-02-2013, 07:42 PM   #6
2010 22' Sport
Carver , Massachusetts
Always had the hump on mine, figured it was just due to the fact that the table top sits on top of the seats and accepted it. My now 4 year old has never complained about discomfort, so I've never given it a second thought. Given that the table top is bigger than the space between the seats, I don't see how one would ever achieve a flush condition.
The one complaint I've always had is the slides, they seem to be pretty poor quality, always leaving the table top feeling a bit wobbly.
etobolski is offline   Reply With Quote
Need help 08 or 09 sport 22 bcripe Airstream Trailer Forums 7 10-15-2009 02:15 PM
JC With Problems, Same Problems Goin Home ncbambi 2008 Safari SE 3 06-23-2009 09:44 PM
New Safari Sport Silvertwinkie 2007 Safari 7 04-07-2008 07:53 PM
Safari Sport 17 jdthor Member Introductions 26 09-09-2007 06:02 PM
Update on Problems Problems pjude General Motorhome Topics 4 09-04-2007 06:02 AM
