Old 02-18-2018, 05:34 AM   #1
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Split in exterior at segment protector mount
I discovered a few cracks in the exterior of my Bambi at the mount for the segment protector on front right side. How to repair?......or do I have to replace the entire panel/section?
LittleLucy is offline   Reply With Quote
Old 02-18-2018, 07:52 AM   #2
1977 31' Sovereign
Sunset Valley , Texas
Hey there,
I’d probably pull off the segment protectors and brackets then tastefully add a reinforcement patch under each bracket of thicker aluminum sheet stock.
I had a similar situation on my Avion on the hold-downs for my window rock guard and this is what I did to fix it.
Replacing the whole panel seems like overkill and before you know it you’d be doing a full monte shell off and adding a second story...
Ian
Iansk is offline   Reply With Quote
Old 02-18-2018, 08:46 AM   #3
Central , Mississippi
Here ya go.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-18-2018, 08:53 AM   #4
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
-Remove bracket
-Reseal crack and holes
-Reinforce with aluminum backer plate - could be creative with size and shape
-Reattach bracket
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 02-18-2018, 05:43 PM   #5
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Originally Posted by Iansk View Post
Hey there,
Ian
I think I will patch as suggested. Best to not go two stories on a 19' footer might get a bit top heavy!
Old 02-18-2018, 05:44 PM   #6
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Originally Posted by HiHoAgRV View Post
Here ya go.
Thanks! Looks like the way to go!
Old 02-18-2018, 05:45 PM   #7
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Originally Posted by FishByFly View Post
-Remove bracket
-Reattach bracket
Know what I'll be doing in the next few days! Thanks for the help!
Old 02-18-2018, 08:31 PM   #8
57Vintage's Avatar
1957 26' Overlander
Battle Ground , Washington
Images: 21
Aluminum repair
Would suggest you drill a small hole at the end of the crack to reduce chance of it continuing. Like plexiglas the crack will continue to grow if there is any stress on the panel.
Harold & Rebecca
http://www.airforums.com/forums/f97/...er-172124.html
57Vintage is offline   Reply With Quote
Old 02-18-2018, 09:45 PM   #9
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Maybe old eyes, but could that be filiform corrosion rather than a crack? If so clean gently anf treat with formula 303, and seal with clearcoat (OR silver fingernail polish)
Old 02-18-2018, 10:09 PM   #10
2007 22' International CCD
There looks to be filiform around parts of the area, but I would bet there’s a growing crack as well. I would wonder what made the crack start, and also try to eliminate the root cause, if at all possible.
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 03-18-2018, 10:12 AM   #11
LittleLucy's Avatar
2002 19' Bambi
Bowdon , Georgia
Here ya go.
Thanks....what size rivet did you use? 1/8 x 3/16?
Segment Protector install equigley 1969 - 1973 Safari 3 02-07-2015 07:05 AM
Segment protector ticki2 Rock Guards, Segment & Window Protectors 4 10-21-2008 05:53 PM
Segment Protector Corrosion chaunceyboy Ribs, Skins & Rivets 27 06-14-2007 07:05 PM
Need a source for Segment Protector latch R&SZinser Rock Guards, Segment & Window Protectors 9 10-04-2006 07:47 PM
?? Lower segment protector fit ?? driftwood Rock Guards, Segment & Window Protectors 1 03-07-2005 04:09 PM
