Old 10-24-2012, 06:35 PM   #1
2000 19' Bambi
Bowling Green , Ohio
spare tire protection or not.
The spare tire on our 2000 Bambi is mounted on a swing down frame just behind the hitch.
The previous owner had the spare tire covered with a vinyl elastic cover with the open side facing down. I'm not sure it protects the steel wheel since it is exposed to the salt spray and gravel any way. If I reverse the cover and enclose the bottom I am concerned that I will just trap moisture inside the cover and make conditions worse for the rim.
I would welcome any thoughts on covering or not.
oldwoodguy is offline   Reply With Quote
Old 10-24-2012, 06:59 PM   #2
SteveH's Avatar
Common Sense , Texas
I thought tire covers were in use to protect the tire from UV and sunlight. Don't think that's a problem under the body.
Old 10-24-2012, 07:33 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Never have seen a spare covered in an underbelly rack. I doubt there's a need to cover it ... You're right, though ... with the open side up it woud trap moisture ... probably not a good thing.
TB & Greg and Abbey Schnauzer
#3954
Old 10-31-2012, 06:43 PM   #4
2000 19' Bambi
case closed
Thanks for your input. I was leaning away from the cover and it makes me more confident that you agree.
Old 10-31-2012, 07:07 PM   #5
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I know you've already decided, but I'll add that I wouldn't bother. Our spare, under there a year now, still looks new without a cover. (Unfortunately I keep having reasons to pull it out, so I know what condition it's in.) It's protected from sunlight under there.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
