Old 05-04-2010, 03:53 PM   #1
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Spare Tire carrier question
I am posting this again in the General Repair area in hopes of getting a few more people viewing it. Thanks for understanding......
I have a 1997 Excella. The original owners planned on keeping the trailer in Penn Woods and not towing, so they had the factory delete several standard items. One being the spare carrier. Now that I own it and want to tow, I need to install a carrier. The carrier assembly is readily available, but someone mentioned a plastic bin that goes above the carrier against the belly of the trailer. Is that correct for a 1997 34' Excella? Does the bin go over the surrounding belly skin? I am guessing I will have to cut out a section of the current skin to install the carrier. All input would be appreciated. Especially pictures and Airstream part number for the plastic part if it is indeed part of the install.
Craig
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 05-04-2010, 06:31 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I know we've got several of that age sitting around, I'll go crawl under a couple and verify for you. AFAIK, there doesn't need to be a bin, but the belly pan skin does need to be cut out and attached against the bottom of the floor where the spare tire carrier goes. If I don't post a reply back by this time tomorrow, please shoot me a PM, as I'll have probably forgotten.
Old 05-04-2010, 06:45 PM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I had a 97 Safari and it did not come with a spare tire carrier, but I had the factory intstall one for me. No modifications had to be made, there was already sufficient space that allowed the tire carrier to be installed.
My current rig, a 98 Limited, has the same spare tire carrier installed. I suspect if you look under your rig, you will see that there is more room at that point than there is further astern - indicating that you have room to install your carrier. I think it was less than $200 for the installation.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 05-04-2010, 07:36 PM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thank you both. I look forward to Terry's pics of how it is supposed to look. Andy told me there wasn't a plastic bin, and the guy at Colaws said there was one. Which of course is confusing for us newbies.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 05-04-2010, 07:47 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
On my 77 I cut out the pan,between the Aframe,sealed the floor with a wall sealer used behind tile,
copied the mount from the 73 and it worked great.Can`t say for sure if it [the 73] had a bin or not.
Dave
easyride is offline   Reply With Quote
Old 05-04-2010, 07:51 PM   #6
Central , Mississippi
I've got a few photos in a floor replacement thread...
http://www.airforums.com/forums/f36/...oor-54952.html
Specifically...
http://www.airforums.com/forums/f36/...tml#post738344
...that may show the aluminum panel. It sits on top of the frame rail. If I were retrofitting, I'd simply cut out the belly, rivit the edges to the frame and cover the exposed wood/insulation of the bottom of the floor with some scrap aluminum, using really short screws...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 05-09-2010, 09:30 AM   #7
Well Preserved
1993 21' Sovereign
Here are a couple of pictures I took, all are pretty much the same, so I won't bore y'all with multiple pictures of the same thing:
ID:	102145   Click image for larger version
Old 05-09-2010, 10:50 AM   #8
spare tire carrier
Our part # 10975 photo, shows the Airstream spare tire carrier.
Old 05-09-2010, 10:55 AM   #9
Airstreams spare tire carrier
Oops.
Old 05-09-2010, 07:51 PM   #10
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks guys. From the looks of the pictures and carrier it is just a matter of opening space in the belly skin, attaching it up near the floor, then mounting the carrier rack to the back of the "A" . Correct?
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 05-09-2010, 08:01 PM   #11
Absolutely correct.
Sometimes, an intended savings can lead to distorted ways to do things, or the way somone did something, and blames the factory.
Ah yes, what a simple job of installation it is.
Old 05-09-2010, 08:55 PM   #12
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
You are so right. My in-laws were the original owners, and they paid extra $ to Airstream to delete the spare tire carrier, and rock guards for both the windows and lower front body. Guess what I am spending money on now......
For them it was a reasonable decision as this was the Penn Woods trailer and they had another at Travelers Rest for the Winter. After years of full timing and doing the Caravan tours, they wanted to be able to just drive between the two without towing any longer.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 05-09-2010, 10:02 PM   #13
Well Preserved
1993 21' Sovereign
You are so right. My in-laws were the original owners, and they paid extra $ to Airstream to delete the spare tire carrier, and rock guards for both the windows and lower front body. Guess what I am spending money on now.......
It could be worse, at least you can still get the rock guards and spare tire carrier from any Airstream dealer.
Old 05-10-2010, 08:10 AM   #14
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
True. I have the window guards now thanks to ebay, and am watching for a pair of lower ones. The '97 has dual battery compartments, so I need the ones with cutouts for that. Colaws wanted the new retail price for a used tire carrier, so I will by a new one and get to work.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Spare tire carrier 68 TWind Wheels, Hubs & Bearings 4 09-27-2009 08:33 PM
Spare Tire Carrier oldtrucksrul Exterior Storage Compartments & Access Doors 5 09-06-2009 09:49 PM
spare tire carrier Argy 78 Wheels, Hubs & Bearings 1 01-29-2008 06:22 PM
Spare Tire Carrier AirHeadRik Tires 21 04-20-2005 12:24 AM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 10:00 AM
