Old 06-23-2016, 11:33 AM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Spare in the truck bed or under the Airstream?
After changing the 14" wheels & tires on our 23D to fifteen inchers, I'm left with a spare tire that won't fit back into its under-trailer cradle unless the cradle is modified. I'm wondering about taking the easy way out...
Why not just carry the spare in the covered truck bed? We don't carry much back there anyway, so it would fit easily. So, what difference would it make to weight distribution and "payload" and all that stuff if the tire is in the truck or under he trailer? Beats me.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 06-23-2016, 11:48 AM   #2
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
we carry the spare in the truck bed, our trailer didn't come with a spare tire mount. the weight of the spare is not significant to our trailer or truck and we have the space. Biggest drawback is having to remember to put the spare in the truck and not leave it at home when we hit the road.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 06-23-2016, 11:52 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sure, just put it far forward as possible to help with weight distribution. If the new Airstream tires are top quality, you could leave the spare at home for many travels. Not so many years ago, a spare tire was an Airstream option. And now we have more reliable tires.
Should you ever get a flat, there is a procedure in your Airstream Owners Manual to remove one tire (the flat one) and proceed at reduced speed and limited distance on the remaining three tires (tandem axle Airstream) to get home, or fixed or replaced.
Doug and Cheryl
Old 06-23-2016, 05:13 PM   #4
Kittyfeet's Avatar
2016 23' Flying Cloud
Dallas , Texas
I have the truck spare, normally mounted under the truck, and trailer spare in the bed of the truck. Also did that for my granddaughter and her 20 footer. Makes it so much easier to get them out rather than have to remove them from the carrier. Especially if you are hooked up to TT. Would not work for someone that carries a lot of stuff in the bed but I like it that way.
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
Kittyfeet is offline   Reply With Quote
Old 06-23-2016, 06:22 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Do you have a portable air compressor in your AS tool kit?
Yes....let some air out.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 06-24-2016, 09:08 AM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
When I changed my 15" wheels (with GYM tires) for 16" wheels (with Michelin LTX tires), JC made the small modification to enlarge the under-AS spare carrier. JC said it was a minor fix. On that basis, I would suggest the mod.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 06-24-2016, 03:00 PM   #7
Greeneville , Tennessee
Spare in truck bed or under the Airstream
Why not just use a 14 inch tire for a spare ?
ChrisPBacon is offline   Reply With Quote
Old 06-24-2016, 03:05 PM   #8
dcasr's Avatar
1990 29' Excella
Stone Mountain , Georgia
I've travelled in Montana, Wyoming and the Dakotas, Nevada etc and had two trailer flats at once. I carry one AS spare under the AS and the second spare in the pickup bed mounted upright to one forward sidewall. May be overkill but works for me. I have all tires including spares with tire monitors so I know the temp and PSI. More peace of mind.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
dcasr is offline   Reply With Quote
Old 06-24-2016, 04:56 PM   #9
dkottum's Avatar
When we changed from 15" GYM to 16" Michelins we kept the original 15" spare, for the very unlikely event we'll ever need it. No TPMS, that money went to a highly reliable tire upgrade for peace of mind.
Doug and Cheryl
Old 06-24-2016, 05:10 PM   #10
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We built a custom tire carrier for the 23D to carry the 15" Michelin spare. That spare tire and wheel weight is part of our 968 pound tongue weight fully loaded for camping.
It was a minor bend the arms out on the tire carrier in the 25FB when The Michelins were put on.. The challenge was they were fatter in cross section so getting the lock in place was a challenge. The Classic was a similar situation.
switz is online now   Reply With Quote
Old 06-24-2016, 06:15 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I moved up to 16" wheels to use LT tires on our trailer. The 16" would not fit in the spare tire carrier under the front of the trailer.
I contemplated either bending or cutting/welding the tire carrier to suit, but then decided that I would rather not leave the shiny new aluminum wheel under the trailer to be covered in dirt and road salt anyway, so I just decided to carry it in the bed of the truck.
We have a full cap on the truck and lost of space so it works fine - been doing it three or four years now. Never had to use it yet!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 06-24-2016, 09:19 PM   #12
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
My AS had the tire on the rear bumper which I didn't like so I moved it into the Tundra...
I built a "Big Drawer" in the back of my truck and planned a spot upfront totally out of the way in a lower storage area... I need to move a few things but its a great spot for it..... hopefully I never need it.
rucos is offline   Reply With Quote
Old 06-24-2016, 09:37 PM   #13
dkottum's Avatar
We've been towing our Airstreams all over the country for seven years, never used the spare tire. It's our nature in 50 years of travel and camping to travel simple and light. I'm thinking of leaving it behind from now on and rely on the Owners Manual three wheel method if we should ever have a flat.
Doug and Cheryl
Old 06-24-2016, 10:07 PM   #14
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Rob
Hey Rob, I'm just down the road in Euless.
My trailer is vintage and was light in the tongue compared to the trailer weight (less than 10%) so I moved the propane tanks forward a bit and mounted the spare behind them on the tongue. Before that, it was in the truck bed.
rvb is offline   Reply With Quote
Relocating 25FB spare behind axles under floor TRIPPPIN 2009-2015 Flying Cloud 23 03-09-2017 04:59 PM
16" spare tire vs OEM spare tire rack Bluto Wheels, Hubs & Bearings 22 04-30-2013 05:13 AM
Spare tire carrier under rear end. perryg114 Tires 21 11-02-2011 12:34 PM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
Creating a spare for the spare easyride Tires 0 06-10-2008 04:16 PM
