Old 08-09-2013, 09:31 AM   #1
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
Space between belly pan and subfloor?
Sorry, I've tried to find this info as I'm sure its buried in many threads somewhere but can someone tell me:
how much space there is between the belly pans and the subfloor?
I have rivets that need to be replaced but was hoping to use my already owned 3/4" ss screws (yes I know about galvanic corrosion of dissimilar metals) instead for easier access down the road.
thanks
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 08-09-2013, 10:35 AM   #2
1974 Argosy 20
Kooskia , Idaho
The space between the belly pan and the bottom of the sub floor is the depth of your frame. You can measure that at the tongue, probably 4" at least.
Old 08-09-2013, 10:38 AM   #3
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
ah hahaha DUH, my stupidity is showing again...thanks idroba!
I guess I was so busy trying to make it hard that I forgot to think about the potential for easy
WBCCI# 1558
