Old 02-22-2015, 07:43 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Yesterday I made an interesting accidental discovery. While spraying Corrosion X on the 7-way cord plug I got a bit of over spray on the trailer. Went to wipe it off and discovered that it removed some light scratches in the area. Light bulb went off! Went around the rest of the trailer and it removed almost all of the scratches that I could see. Funny part is that that these same scratches have defied the use of several other products specifically designed for scratch removal and cover up including a couple of high priced waxes. It also easily removed some left over glue residue from political bumper stickers put on the back of the trailer by the previous owner.
MICHAEL
Old 02-22-2015, 07:48 AM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Do what Earl says here. Appreciate the concern Round Robin has for you, however, that polish out won't work and you will end up with a big mess as you discover the clear coat and clad type aluminum sheeting. says.
Old 02-22-2015, 11:13 PM   #17
2014 27' Flying Cloud
Conifer , Colorado
Thanks to all. Tomorrow I am going to do some research and contact Airstream and see what they have to say.
coazboyz is offline   Reply With Quote
Old 02-22-2015, 11:29 PM   #18
2014 23' FB International
Campbell River , British Columbia
That is probably very good advice. Wish you good luck and I am sure the pros will be able to fix this.
Cheers
Al
roundrobin is offline   Reply With Quote
Replacement (keyed) deadbolt for '66 AS? mommythrice Doors & Locks 0 06-27-2014 01:18 PM
Curtains - looking for someone to make and Install (incldg tracks (new york area) pgreenx Upholstery, Blinds, Walls & Interior Finishes 1 08-09-2012 08:44 PM
No keys - can we get our locks re-keyed? TexInNC Doors & Locks 4 11-27-2011 02:08 PM
All doors and hatches keyed alike Jammer Exterior Storage Compartments & Access Doors 5 10-13-2010 03:37 PM
Why would someone do this? Chuck Electrical - Systems, Generators, Batteries & Solar 6 07-10-2002 02:53 PM
