Old 03-02-2012, 11:58 AM   #1
n/a , Alaska
Solid rivet questions
I have a question on solid rivets. New to riveting. Anyways, my material is 3/16" thick and the hole diameter is 1/4". So based on what I have read here I should go 1.5 X the diameter and add this to the material thickness, correct? Which would mean my rivet should be 9/16" long. Also I am using flat head style rivets, aluminum. How soft is the aluminum alloy 1100F? Also, I noticed when ordering my rivets online that due to the diameter size I am limited to a flat rivet with a length of 1/2" or 5/8" long, not 9/16" - will that pose a problem? Finally, I would like to use this tool for my rivet hammer:
Tools :: Solid/ Semi-tubular Rivet Tools and Rivet Set :: Solid Rivet 4X, 7X, 9X Rivet Gun Head Sets - Buy Rivets, Rivet tools & Other Fasteners from RivetsOnline
Do I order the 1/4" flat head set? What exactly is the 1/4" spec? The rivet I am using is 1/4" in diameter - will this flat head set work with that? If not, could you advise what I should use? Thanks!!
pityocamptes is offline   Reply With Quote
Old 03-02-2012, 01:14 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
As I have shot a rivet or two, could you let me know where exactly you are installing a 1/4 diameter rivet as I can give you advice once that is known
Old 03-02-2012, 02:02 PM   #3
n/a , Alaska
Thanks. Well I don't own an AS, however I am doing some work on an older IHC Scout and over on the Scout forum they suggested checking on an AS forum as you guys still use the art of riveting.
Hope that helps. Thanks again.
Old 03-02-2012, 03:33 PM   #4
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
pityocamptes,
So what are you trying to rivet together on your Scout. Is it something that was previously riveted together before? Can you post a picture of the task at hand?
Aerowood is the man when it comes to knowledge about sheet metal and riveting!
Steve Bryant is offline   Reply With Quote
Old 03-02-2012, 04:06 PM   #5
n/a , Alaska
Thanks. Its actually something I am putting together inside (using chrome plated diamond plating over a box) - basically adding a tool box in place of the rear seat. So, its not going to be structural strength, thus my question on how soft the aluminum rivets are - don't want to beat on this thing all day... thanks again.
Old 03-02-2012, 05:38 PM   #6
Aerowood's Avatar
Arvada , Colorado
The rivet you refer to is as soft as aluminum gets and really has very little strength. 1100 aluminum is called an "A" rivet and yes you will need the proper rivet set to shoot it, otherwise you will distort the manufactured head into something that that does not resemble a rivet any more and will not have a consistent looking appearance. A "B" rivet might be a better choice depending on availability. When you get in to that 1/4 inch range the available rivets tend to be in the higher shear strengths. You might want to check out some of the Aircraft hardware suppliers as they have more available. If possible I would go with the universal head (470) as this is the most commonly used. The P/N for a 1/4 dia "A" rivet with the universal head would be MS20470A8-9. You could most likely get away with a -8 length which is 1/2" long. Hopes this helps
Genuine Aircraft Hardware Co.
Couple questions - polishing Northlander Cleaning, Stripping & Polishing 15 06-12-2013 09:06 AM
Vista View Window Questions CBWELL Windows & Screens 15 07-07-2012 08:36 PM
Lots of Generator Questions!! lewishw Boondocking 45 03-02-2012 09:12 PM
Can-Am RV Customers Questions CallDon Our Community 15 03-02-2012 07:24 AM
Greetings and hello with questions rodsterinfl Member Introductions 36 02-24-2012 03:02 PM
